Find magnitude of current of 2 wires separated by an angle
In summary, the conversation revolved around finding the magnitude of current in two long straight wires of equal current, connected by lightweight and inelastic threads. The wires were suspended at an angle of 16 degrees and had a linear mass density of 40 g/m. The conversation discussed using the formula F = qv x B = qvBsin(theta) to solve for the current, but ultimately, it was suggested to use a Newtonian analysis to find the force on each electron. The conversation also touched on the consequences of removing one of the wires from its equilibrium position.
ichivictus
39
A telegraph consisted of 2 long straight wires carrying currents equal in magnitude but oppositely directed. Each was suspended by a pair of light-weight and inelastic threads that were about 6cm long. When current flowed through the wires, the magnetic force exerted between them caused them to move apart.
Given that the linear mass density of the wire is 40 g/m, find the magnitude of the current in either wire when the angle separating the threads of the device is 16 degrees.
Here's a pic of the object: http://i.imgur.com/zwZLzPX.png
B = U/2∏ * I/R (Due to a long straight wire) (U is the permeability of empty space.)
I tried solving for B from the first equation then plugging it into the 2nd then solving for I.
I = FR2pi/qvsin(theta)
But I'm pretty much stuck. I think I'm missing something really simple but not sure. I know I'm going to need to write an expression of the mag field due to the current in a long straight wire and force on a long straight wire carrying some current though.
Any hints would be great :)
Draw a free-body diagram of one of the wires, showing the magnitudes and directions of the forces involved.
Also, you need to dig up the formula for the force between two parallel wires carrying current. (Or you can derive it from F= qv x B and Ampere's law. You've already stated that law).
Yea the right hand rule is a bit confusing but I think I got it.
The force you are talking about is F1 = B2I1L where L is the length (6cm).
And since the current is equal and with this geometry, the forces are equal. As such, both their magnetic fields should be equal.
Also since it's going about an angle as shown, I can use qB = mv/r I think.
All my work has q in it from F=qvBsin(theta)... would I use a charge of a proton for q?
I don't think 6 cm is the length of the wire. They are long straight wires, and the cables that hold them up are 6 cm (it's a radius).
You want forces, but ultimitely you'll have forces acting on an object suspended by a string which can rotate from pi -> 2pi.
Right. Except L is not 6 cm, as post 2 indicates. L is arbitrary.
The forces are always equal, even if the two fields were not.
This formula is totally irrelevant. It describes a charge moving circularly in a B field. No motion here.
Oh right, duh.
Alright so I was probably right in thinking it requires the F = qvBsin(theta). Where theta will probably be 16 degrees.
However, that q in that equation confuses me.
So this is what I got now:
F = BIL = mv^2/r = qvBsin(theta)
I = mv^2/(BLR) = qvsin(theta)/L
So I have a velocity in one and that q and velocity in the other... both of which I don't know. I don't think substituting for one variable and inputting to the other would help at all.
ichivictus said:
Oh right, duh.
I think you're missing the point here. The theta in that equation comes from the fact that it's actually ##qv \times B = F##
Its a cross product between the velocity of the CHARGE and the magnetic field its traveling through. You need to do a Newtonian analysis of the situation, but you don't want F=qv×B. You can do that, but you have to sum up the force on every single electron. Theres a better equation that was mentioned in this thread.
What happens when the 6cm wires make a 16 degree angle from the vertical?
what would happen if you spontaneously removed one of the wires from this equilibrium position? What motion would the remaining wire exibit?
did you ever find your answer to this problem??
Not sure, they just kinda stopped posting.
Related to Find magnitude of current of 2 wires separated by an angle
1. What is the formula for finding the magnitude of current of 2 wires separated by an angle?
The formula for finding the magnitude of current of 2 wires separated by an angle is given by I = I1^2 + I2^2 + 2I1I2cosθ, where I1 and I2 are the currents in the two wires and θ is the angle between them.
2. How do you determine the direction of the current in this situation?
The direction of the current can be determined by using the right-hand rule. Point your thumb in the direction of the first current, your index finger in the direction of the second current, and your middle finger will point in the direction of the resulting current.
3. Can the magnitude of current be negative in this scenario?
No, the magnitude of current cannot be negative in this scenario. Current is a scalar quantity and its magnitude is always positive, regardless of the direction of the current.
4. What is the significance of the angle between the two wires?
The angle between the two wires determines the amount of mutual inductance between them. A larger angle means less mutual inductance, resulting in a smaller magnitude of current, while a smaller angle means more mutual inductance and a larger magnitude of current.
5. How does the distance between the wires affect the magnitude of current?
The distance between the wires does not directly affect the magnitude of current. However, the closer the wires are, the higher the mutual inductance between them, which in turn can result in a larger magnitude of current. The distance between the wires does not have a direct effect on the magnitude of current but it can indirectly affect it through mutual inductance.
