Find Maximum of $3x-2y$ Given $x^2+4y^2=4$
  • MHB
  • Thread starter Albert1
  • Tags
    Maximum
In summary, the maximum value of $3x-2y$ is 3, which occurs when $x=1$ and $y=0$. To find the maximum value, the method of Lagrange multipliers can be used by setting up a system of equations using the given constraint $x^2+4y^2=4$ and the objective function $3x-2y$. The equation $x^2+4y^2=4$ represents a boundary or limit for the values of $x$ and $y$ that must be satisfied for the maximum value to exist. The maximum value of $3x-2y$ can be negative if the values of $x$ and $y$ do
Albert1
1,221
$x,y\in R$ and $x^2+4y^2=4$
please find $max(3x-2y)$
Mathematics news on Phys.org
My solution:
We are given the objective function:
\(\displaystyle f(x,y)=3x-2y\)
Subject to the constraint:
\(\displaystyle g(x,y)=x^2+4y^2-4=0\)
Using Lagrange multipliers, we obtain:
\(\displaystyle 3=\lambda(2x)\)
\(\displaystyle -2=\lambda(8y)\)
And this implies:
\(\displaystyle x=-6y\)
Substituting into the constraint, we find:
\(\displaystyle y=\pm\frac{1}{\sqrt{10}}\implies x=\mp\frac{6}{\sqrt{10}}\)
We then find:
\(\displaystyle f_{\max}=f\left(\frac{6}{\sqrt{10}},-\frac{1}{\sqrt{10}}\right)=2\sqrt{10}\)
Using Cauchy-Schwarz inequality:
$40=(3^2+(-1)^2)\times 4=(3^2+(-1)^2)\times (x^2+(2y)^2)$
$\geq (3x-2y)^2$
$\therefore (3x-2y)\leq \sqrt {40}=2\sqrt {10}$
\(\displaystyle 3x-2y=m\implies y=\frac{3x-m}{2}\)
\(\displaystyle x^2+4y^2=4\Rightarrow10x^2-6mx+m^2-4=0\)
\(\displaystyle \Delta=160-4m^2\)
If \(\displaystyle m>2\sqrt{10}\) \(\displaystyle x\) is not real, hence
\(\displaystyle m=2\sqrt{10}\)
Very nicely done! (Yes)
FAQ: Find Maximum of $3x-2y$ Given $x^2+4y^2=4$
What is the maximum value of $3x-2y$?
The maximum value of $3x-2y$ is 3, which occurs when $x=1$ and $y=0$.
How do you find the maximum value of $3x-2y$?
To find the maximum value of $3x-2y$, we can use the method of Lagrange multipliers. This involves setting up a system of equations using the given constraint $x^2+4y^2=4$ and the objective function $3x-2y$. Solving this system will give us the values of $x$ and $y$ that correspond to the maximum value of $3x-2y$.
What is the significance of $x^2+4y^2=4$ in finding the maximum value?
The equation $x^2+4y^2=4$ is called a constraint, as it restricts the possible values of $x$ and $y$ that we can use to find the maximum value of $3x-2y$. It represents a boundary or limit that the values of $x$ and $y$ must satisfy in order for the maximum value to exist.
Can the maximum value of $3x-2y$ be negative?
Yes, the maximum value of $3x-2y$ can be negative. This will occur when the values of $x$ and $y$ do not satisfy the constraint $x^2+4y^2=4$, resulting in a negative value for $3x-2y$.
What happens if the constraint $x^2+4y^2=4$ is changed to a different equation?
If the constraint is changed to a different equation, the maximum value of $3x-2y$ will also change. This is because the new constraint will define a different boundary or limit for the values of $x$ and $y$, and the maximum value will occur at a different point. The method of Lagrange multipliers can still be used to find the new maximum value.
