MHB Find Min of $(a-1)^4+(b+2)^4$ w/ $a+b\ge 3$
  • Thread starter Thread starter anemone
    Minimum
The minimum value of the expression $(a-1)^4+(b+2)^4$ under the constraint $a+b\ge 3$ occurs when specific values of $a$ and $b$ are chosen to minimize the function. By analyzing the function, it is determined that the minimum is achieved at the point where $a=1$ and $b=2$, resulting in a minimum value of 0. The constraint $a+b\ge 3$ is satisfied with these values. The discussion emphasizes the importance of finding optimal values for the variables to minimize the expression effectively. Overall, the solution demonstrates a clear approach to solving the problem within the given constraints.
anemone
MHB
POTW Director
Let $a$ and $b$ be real numbers such that $a+b\ge 3$.
What is the minimum value of the expression $(a-1)^4+(b+2)^4$?
Mathematics news on Phys.org
let $m = a - 1$ and $n = b+ 2$
we get $m+n = a + b + 1 >= 3+ 1 >= 4$
we need to minimize $m^4+n^4$ given $m+n>=4$ and from law of symmetry it is minumum at
$m=n=2$ or $a=3, b=0$ and value is $32$. as at a = 1 b = 2 it is $4^4= 256$ larger
I like how you cleverly coaxed cyclic symmetry from the problem...well played! (Yes)
The lowest values for $a$ and $b$ must occur when $a+b=3$. This can be seen by graphing the inequality $y\ge3-x$ on the Cartesian axes. As the exponents in the expression are even, negative numbers do not effectively reduce the sum.
Lagrange multipliers:
$$\Lambda=(a-1)^4+(b+2)^4-\lambda(a+b-3)$$
$$\dfrac{d\Lambda}{da}=4(a-1)^3-\lambda=0$$
$$\dfrac{d\Lambda}{db}=4(b+2)^3-\lambda=0$$
$$\dfrac{d\Lambda}{d\lambda}=a+b-3=0$$
$$\Rightarrow4(a-1)^3=4(b+2)^3$$
$$\implies a-1=b+2$$
$$\Rightarrow a-b=3\Leftrightarrow a+b=3$$
$$\Rightarrow2a=6\Rightarrow a=3,\,b=0$$
$$\min\left[(a-1)^4+(b+2)^4\right]=2^4+2^4=32$$
Thanks all for participating!(Cool)
My solution:
$$\begin{align*}(a-1)^4+(b+2)^4&\ge \frac{((a-1)^2+(b+2)^2)^2}{1+1}\text{by the extended Cauchy-Schwarz inequality}\\&\ge \frac{\left(\frac{(a-1+b+2)^2}{1+1}\right)^2}{1+1}\text{again by the extended Cauchy-Schwarz inequality}\\&= \frac{\left(\frac{(a+b+1)^2}{2}\right)^2}{2}\\& \ge \frac{\left(\frac{(3+1)^2}{2}\right)}{2}\text{since}\,\,\,a+b\ge 3\\& =32\end{align*}$$
Equality occurs when $a=3,\,b=0$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
