MHB Find Min of $\frac{a(x^2+y^2+z^2)+9xyz}{xy+yz+zx}$ for $x+y+z=1$
  • Thread starter Thread starter anemone
    Minimum
The discussion focuses on finding the minimum value of the expression (a(x^2+y^2+z^2)+9xyz)/(xy+yz+zx) under the constraint x+y+z=1 for non-negative real numbers x, y, and z, where a is a positive constant. Participants suggest using the Arithmetic Mean-Geometric Mean (AM-GM) inequality to derive the minimum. Corrections were made regarding variable notation, ensuring consistency in the expression. The conversation highlights collaborative problem-solving, with users sharing and validating each other's approaches. The goal remains to express the minimum value in terms of the parameter a.
anemone
MHB
POTW Director
Find, in terms of $a$, where $a \gt 0$, the minimum value of the expression $$\frac{a(x^2+y^2+z^2)+9xyz}{xy+yz+zx}$$ for all non-negative real $x,\,y$ and $z$ such that $x+y+z=1$.
Mathematics news on Phys.org
anemone said:
Find, in terms of $a$, where $a \gt 0$, the minimum value of the expression $$\frac{a(x^2+y^2+c^2)+9xyz}{xy+yz+zx}$$ for all non-negative real $x,\,y$ and $z$ such that $x+y+z=1$.
Correction: it should be z instead of c
applying cyclic symmetry the value is at $x=y=z= \frac{1}{3}$ and the value is a + 1 . the value at $(1,0,0)$ is infinite
Your answer is correct, thanks for participating, kaliprasad!
I hope someone else could solve it without using the property of cyclic symmetry. :)
Using $AP\geq GP$
$\dfrac {a(x^2+y^2+z^2)+9xyz}{xy+yz+zx}
\geq\dfrac {a(x^2+y^2+z^2)}{x^2+y^2+z^2}+\dfrac {9xyz}{xy+yz+zx}$
$\geq a+27xyz=a+1$
(equality holds at $x=y=z=\dfrac {1}{3}$
Albert said:
Using $AP\geq GP$
$\geq a+27xyz=a+1$
Thanks Albert for participating! Your approach is correct and neater than mine!(Cool)
My solution:
Since $9xyz≥4(xy+yz+zx)-1$ (by the Schur's inequality), we can transform the objective function as
$$=a\left(\frac{x^2}{xy+yz+zx}+\frac{y^2}{xy+yz+zx}+\frac{z^2}{xy+yz+zx}\right)+\frac{9xyz}{xy+yz+zx}$$
$$\ge a\left(\frac{x^2}{xy+yz+zx}+\frac{y^2}{xy+yz+zx}+\frac{z^2}{xy+yz+zx}\right)+\frac{4(xy+yz+zx)-1}{xy+yz+zx}$$ (by the Schur's inequality)
$$= a\left(\frac{x^2}{xy+yz+zx}+\frac{y^2}{xy+yz+zx}+\frac{z^2}{xy+yz+zx}\right)+4-\frac{1}{xy+yz+zx}$$
$$\ge a\left(\frac{(x+y+z)^2}{3(xy+yz+zx)}\right)+4-\frac{1}{xy+yz+zx}$$ (by the extended Cauchy-Schwarz inequality)
$$= a\left(\frac{1}{3(xy+yz+zx)}\right)+4-\frac{1}{xy+yz+zx}$$
$$= \frac{a-3}{3(xy+yz+zx)}+4$$
$$\ge \frac{a-3}{3\left(\frac{(x+y+z)^2}{3}\right)}+4$$ since $$xy+yz+zx\le \frac{(x+y+z)^2}{3}$$
$$= a-3+4$$
$$= a+1$$
Therefore, the minimum of $$\frac{a(x^2+y^2+c^2)+9xyz}{xy+yz+zx}$$ is $a+1$, this occurs when $x=y=z$.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
