MHB Find Min of x+y+z for Real x,y,z ≤ 3/2
  • Thread starter Thread starter anemone
    Minimum
The discussion revolves around finding the minimum value of the expression x+y+z+1/x+1/y+1/z under the constraint that x+y+z ≤ 3/2 for positive real numbers x, y, and z. Participants share their solutions and seek clarification on specific steps in the problem-solving process. One user expresses confidence in their answer but requests an explanation for a transition in their solution. The conversation highlights the collaborative nature of mathematical problem-solving, with users helping each other understand complex steps. Ultimately, the discussion emphasizes the importance of clear communication in resolving mathematical queries.
anemone
MHB
POTW Director
Find the minimum of $x+y+z+\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}$ for all positive real $x,\,y$ and $z$ that satisfies the condition $x+y+z\le \dfrac{3}{2}$.
Mathematics news on Phys.org
$$x+y+z+\dfrac1x+\dfrac1y+\dfrac1z\ge\dfrac32+a$$ where $a$ is some non-negative constant.
$$x+y+z-\dfrac32+\dfrac1x+\dfrac1y+\dfrac1z\ge a$$
$$b=x+y+z-\dfrac32\implies-\dfrac32\lt b\le0$$
$$\dfrac1x+\dfrac1y+\dfrac1z\ge a+|b|$$
Applying the AM-GM inequality, we have $$\dfrac{\dfrac1x+\dfrac1y+\dfrac1z}{3}\ge\left(\dfrac{1}{xyz}\right)^{1/3}$$
hence $$\dfrac1x+\dfrac1y+\dfrac1z$$ is at a minimum when $x=y=z=\dfrac12$.
From this, $b=0$ and $a=6$, so the desired minimum is $6+\dfrac32=\dfrac{15}{2}$.
Great job, greg1313!:)
My solution:
Note that from AM-GM inequality we get $3\sqrt[3]{xyz}\le x+y+z\le \dfrac{3}{2}$, which translates to $\sqrt[3]{xyz}\le \dfrac{1}{2}$, we can conclude $\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}\ge \dfrac{3}{\sqrt[3]{xyz}}=\dfrac{3}{\dfrac{1}{2}}=6$.
By AM-HM we have $x+y+z\ge \dfrac{9}{\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}}$ so the intended expression becomes
$x+y+z+\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}\ge \dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}+\dfrac{9}{\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}}$
Since $x,\,y$ and $z$ are positive real numbers and $\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}+\dfrac{9}{\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}}\ge 2\sqrt{\left(\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}\right)\left(\dfrac{9}{\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}}\right)}=6$, we can conclude by now that
$\begin{align*}x+y+z+\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}&\ge \dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}+\dfrac{9}{\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}}\\&\ge 6+\dfrac{9}{6}\\&\ge \dfrac{15}{2}\end{align*}$
Equality occurs when $\dfrac{1}{x}=\dfrac{1}{y}=\dfrac{1}{z}=\dfrac{1}{2}$.
My solution:
Since $x,\,y$ and $z$ are positive real numbers and $\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}+\dfrac{9}{\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}}\ge 2\sqrt{\left(\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}\right)\left(\dfrac{9}{\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}}\right)}=6---(A)$, we can conclude by now that
$\begin{align*}\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}+\dfrac{9}{\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}}\\\ge 6+\dfrac{9}{6}\ge \dfrac{15}{2}---(B)\end{align*}$
I know the answer is correct but---
step from (A)to (B) can you explain ?
Albert said:
My solution:
Sorry Albert that I wasn't clear...
I will explain using the example function of $f(a)=a+\dfrac{9}{a}$, note that we can apply the AM-GM inequality to the function of $f$ when $a$ is positive to get $f(a)=a+\dfrac{9}{a}\ge 2(3)=6$. Equality happens when $a=3$.
And we know the function of $f$ is an increasing function beyond $a=3$. Since $a\ge 6$, the minimum of $f$ would then occur at $a=6$, so we get $f(a)_{min}=6+\dfrac{9}{6}=\dfrac{15}{2}$.
many thanks! now I got it
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
