MHB Find Minimal Sum of Distances: (1,2) & (4,3) on Axis OX
  • Thread starter Thread starter leprofece
    Sum
leprofece
239
find a point on the axis OX whose sum of distances to landmarks: (1, 2) and (4, 3) is minimal.
Answer (2,0)
(x-1)2+(y-2)^2 +
(x-4)2+(y-3)^2 = D
Y = mx
I don't know if solve each distance apart or how i wrote??
Re: sum of distances
Your point on the $x$-axis may be written as $(x,0)$, and so the objective function is:
Minimizing this gives a different result than what you cite though. (Thinking)
I don't know but the 2 roots must be
((x-2)2+4)1/2+ (x2+9)1/2 = D When I derive an equated to 0 I got (6,0)
the roots that my friend markflo wrote if he didnot make a mistake why are they so??
No, the answer is NOT (2, 0).
The simplest way to do this problem is:
Change the second point to (4, -3) on the opposite side of the x-axis. A straight line is the shortest distance between two point and the straight line from (1, 2) to (4, -3), which has equation y= (-5/3)x+ 11/3, crosses the x-axis when (-5/3)x+11/3= 0 or x= 11/5= 2.2.
Now, draw a picture showing all three points, (1, 2), (4, 3), and (4, -3) and use "congruent triangles" to show that the answer to the given problem is also (2.2, 0).
(This is referred to as the "method of reflections.)
The real answer is (21/5,0)
do it Change the way of solution?
No, the point is .
You can find this either minimizing the funtion I gave or much more simply using the method of reflection as shown by HallsofIvy.
MarkFL said:
No, the point is $$\left(\frac{11}{5},0 \right)$$.
Your point on the x-axis may be written as (x,0), and so the objective function is:
f(x)=(x−1)2+4−−−−−−−−−−√+(x−4)2+9−−−−−−−−−−√
ok friend mark Thanks
I MUST minimize because I an asked to do so
I tried deriving and I did not get it
OK
operating
(x2-2x+5)1/2+(x2-8x+25)1/2
Deriving
(x-1)/(x2-2x+5)1/2+(x-4)/(x2-8x+25)1/2
Equating to 0
(x-4)(x2-2x+5)1/2+(x-1)(x2-8x+25)1/2= 0
And Squaring
(x-4)2(x2-2x+5) =(x-1)2(x2-8x+25)
I don't know here if I and doing well because I get a cubic equation after that
Please tell and help me (Blush)
Okay, our objective function is:
So, differentiating and equating the result to zero, we obtain:
We see there are no real roots in the denominator, so we are left with:
Square both sides:
Distribute:
Arrange as:
Factor as difference of squares:
Distribute and collect like terms:
Checking both roots, we find the root $x=-5$ is extraneous, but the root is valid.
Now, to show that this critical value is at a minimum, we can use the first derivative test:
and so we may conclude that the point:
is the solution.
The only thing that i don't know
Is where do they some values come from??
One Point is (1,2)
another is (4,3)
I understood (x - 12)2+22 This is root 1
The second root = (x - 22)2+32
I hope It will be so?
The distance from the variable point $(x,0)$ and the given fixed point $(1,2)$ is:
The distance from the variable point $(x,0)$ and the given fixed point $(4,3)$ is:
The sum of these distances is our objective function:
