MHB Find Minimum of Inequality Expression: 0<x<π/2
  • Thread starter Thread starter Saitama
    Inequality
The discussion focuses on finding the minimum value of the expression $$\frac{\sin^2x+8\cos^2x+8\cos x+\sin x}{\sin x\cos x}$$ for the interval 0 < x < π/2. It is established that the minimum value is 17, which can be shown using inequalities rather than calculus. The transformation using $t = \tan\frac{x}{2}$ simplifies the expression, leading to the inequality that confirms the minimum. The minimum occurs when $\tan\frac{x}{2} = \frac{2}{3}$, corresponding to specific sine and cosine values derived from the Pythagorean triple (5, 12, 13). The findings highlight a clever approach to solving the problem through algebraic manipulation and inequality analysis.
Saitama
I am trying to find the minimum of the following expression:
$$\frac{\sin^2x+8\cos^2x+8\cos x+\sin x}{\sin x\cos x}\,\,\,,0<x<\frac{\pi}{2}$$
I know I can bash this with calculus but the expression has a nice minimum value (=17) which makes me think that it can be solved by use of some inequality though I have no idea about how to proceed.
Any help is appreciated. Thanks!
Mathematics news on Phys.org
Let $t = \tan\frac x2$. Then $\sin x = \frac{2t}{1+t^2}$ and $\cos x = \frac{1-t^2}{1+t^2}$. We want to show that $\sin^2x+8\cos^2x+8\cos x+\sin x \geqslant 17\sin x\cos x$, or $\sin x(\sin x+1) + 8\cos x(\cos x+1) - 17 \sin x\cos x \geqslant0.$ In terms of $t$ (after multiplying through by $(1+t^2)^2$), that becomes $$2t(2t+ 1+t^2) + 8(1-t^2)(1-t^2 + 1+t^2) - 34t(1-t^2) \geqslant0,$$ $$t(1+t)^2 + 8(1-t^2) - 17t(1-t^2) \geqslant0.$$ That simplifies to $18t^3 - 6t^2 - 16t + 8\geqslant0$, or $9t^3 - 3t^2 - 8t + 4\geqslant0$, which in turn factorises as $(3t-2)^2(t+1) \geqslant0.$ But $t>0$ because $x$ lies between $0$ and $\frac\pi2$. So that last inequality is evidently true (with equality holding only when $t = \frac23$), and you can work backwards to conclude that the original inequality holds for all $x$ in that interval.
The minimum of $\frac{\sin^2x+8\cos^2x+8\cos x+\sin x}{\sin x\cos x}$ occurs when $\tan\frac x2 = \frac23$, at which point $\sin x = \frac{12}{13}$ and $\cos x = \frac5{13}$. So the question is somehow based on the Pythagorean triple $(5,12,13)$.
Opalg said:
Let $t = \tan\frac x2$. Then $\sin x = \frac{2t}{1+t^2}$ and $\cos x = \frac{1-t^2}{1+t^2}$. We want to show that $\sin^2x+8\cos^2x+8\cos x+\sin x \geqslant 17\sin x\cos x$, or $\sin x(\sin x+1) + 8\cos x(\cos x+1) - 17 \sin x\cos x \geqslant0.$ In terms of $t$ (after multiplying through by $(1+t^2)^2$), that becomes $$2t(2t+ 1+t^2) + 8(1-t^2)(1-t^2 + 1+t^2) - 34t(1-t^2) \geqslant0,$$ $$t(1+t)^2 + 8(1-t^2) - 17t(1-t^2) \geqslant0.$$ That simplifies to $18t^3 - 6t^2 - 16t + 8\geqslant0$, or $9t^3 - 3t^2 - 8t + 4\geqslant0$, which in turn factorises as $(3t-1)^2(t+1) \geqslant0.$ But $t>0$ because $x$ lies between $0$ and $\frac\pi2$. So that last inequality is evidently true (with equality holding only when $t = \frac23$), and you can work backwards to conclude that the original inequality holds for all $x$ in that interval.
This is nice! Thanks a lot Opalg! (Sun) (Bow)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
