Find Minimum of y: $y=2a+\sqrt{4a^2-8a+3}$
  • MHB
  • Thread starter anemone
  • Tags
    Minimum
In summary, the minimum value of y can be found by setting the derivative of y with respect to a equal to 0 and solving for a. This can also be used to find the vertex of the parabola. The minimum value of y represents the lowest point on the graph of the function and can be negative in certain cases. It is also useful in determining the optimal value of a in real-world scenarios.
anemone
MHB
POTW Director
3,883
115
Find the minimum of the function $y=2a+\sqrt{4a^2-8a+3}$.
Mathematics news on Phys.org
for $a<0$
if $a\rightarrow -\infty , \,\, f(a)\rightarrow 2$
if $ a\rightarrow 0^-,\,\,f(a)\rightarrow \sqrt 3$
for $a\geq 0$
by using $AP\geq GP$
if $4a^2=4a^2-8a+3$ then $a=\dfrac {3}{8}$
and $f(\dfrac {3}{8})=1.5$
for: $\dfrac {1}{2}<a<\dfrac {3}{2}$ we get :$y=f(a)$ undefined
$4a^2-8a+3\geq 0$
if :$4a^2-8a+3=0 ,$ then $a=\dfrac {1}{2}$ or $a=\dfrac {3}{2}$
and the minimum of the function =$2\times \dfrac {1}{2}=1\,\,(with \,\, a=\dfrac {1}{2})$
Solution of other:
Note that the function of $y$ is concave and continuous over the domain $\left(-\infty,\,\dfrac{1}{2}\right]\cup \left[\dfrac{3}{2},\,\infty\right)$, so it will have its minimum at anyone of the end points $-\infty,\,\dfrac{1}{2},\,\dfrac{3}{2},\,\infty$ and upon checking we get $y_{\text{min}}=2\left(\dfrac{1}{2}\right)+0=1$.
FAQ: Find Minimum of y: $y=2a+\sqrt{4a^2-8a+3}$
What is the minimum value of y?
The minimum value of y is 3. This can be found by setting the derivative of y with respect to a equal to 0 and solving for a.
How do you find the minimum of y?
The minimum of y can be found by taking the derivative of y with respect to a, setting it equal to 0, and solving for a. Then, plug in the value of a into the original equation to find the minimum value of y.
What is the significance of the minimum value of y?
The minimum value of y represents the lowest point on the graph of the function. This can be useful in determining the optimal value of a in a real-world scenario or in understanding the behavior of the function.
Can the minimum value of y be negative?
Yes, the minimum value of y can be negative if the function has a negative leading coefficient or if the minimum occurs at a negative value of a.
What is the relationship between the minimum value of y and the vertex of the parabola?
The minimum value of y is equal to the y-coordinate of the vertex of the parabola. This is because the vertex is the point on the parabola where the derivative is equal to 0, resulting in the minimum value of y.
