Find minimum stopping distance of a car
In summary, the problem is asking to find the minimum stopping distance for a car moving at 32.0 m/s by applying the brakes, assuming the same frictional forces as a car moving at 14.0 m/s. The attempt at a solution involves setting the equations for the two scenarios equal to each other and solving for distance. The equations to use are those for constant acceleration, with the initial velocity as 14.0 m/s for the first scenario and 32.0 m/s for the second scenario.
evan b
1. Homework Statement
It takes a minimum distance of 66.64 m to stop a car moving at 14.0 m/s by applying the brakes (without locking the wheels). Assume that the same frictional forces apply and find the minimum stopping distance, when the car is moving at 32.0 m/s.
i'm confused on what to do here... i thought it might be as simple as setting them equal to each other and solving for the distance. we know the mass of the car is the same so that isn't a factor. for the first we know Vi=14 m/s and Vf = 0, and the second time its velocity is Vi=32 m/s and Vf = 0. I'm not sure where to go from here...
Which equations do you think might be useful?
As a scientist, the first step in solving this problem would be to identify and define the variables involved. We know that the minimum stopping distance (d) is equal to 66.64 m when the initial velocity (Vi) is 14.0 m/s. We also know that the final velocity (Vf) is 0 m/s and that the frictional forces are the same in both cases.
Next, we can use the formula d = (Vi^2 - Vf^2) / 2a, where a is the acceleration of the car due to the frictional forces. Since we are assuming the same frictional forces in both cases, we can set the two equations equal to each other and solve for the acceleration (a).
66.64 = (14^2 - 0^2) / 2a and d = (32^2 - 0^2) / 2a
Solving for a in both equations, we get a = 3.08 m/s^2. Now, we can plug this value back into either equation to solve for the minimum stopping distance when the initial velocity is 32.0 m/s.
d = (32^2 - 0^2) / 2(3.08) = 166.45 m
Therefore, the minimum stopping distance for a car moving at 32.0 m/s is 166.45 m. This calculation assumes that the car is braking without locking the wheels and that the frictional forces remain constant. It is important to note that in real-life situations, other factors such as road conditions and reaction time of the driver may affect the stopping distance of a car.
FAQ: Find minimum stopping distance of a car
What factors affect the minimum stopping distance of a car?
The minimum stopping distance of a car is affected by several factors, including the speed of the car, the condition of the road surface, and the condition of the car's tires and brakes. Other factors such as the weight and size of the car, as well as external factors like weather conditions, can also play a role.
How is the minimum stopping distance of a car calculated?
The minimum stopping distance of a car is calculated using the equation d = v^2/2u, where d is the stopping distance, v is the initial velocity of the car, and u is the coefficient of friction between the tires and the road surface. This equation takes into account the speed of the car and the road surface conditions to determine the minimum distance the car needs to stop.
How does the minimum stopping distance change with different speeds?
The minimum stopping distance of a car increases as the speed of the car increases. This is because the car has more kinetic energy at higher speeds, making it harder to stop. According to the equation d = v^2/2u, doubling the speed of the car will quadruple the stopping distance.
Can the minimum stopping distance be improved?
Yes, the minimum stopping distance of a car can be improved by maintaining the car's tires and brakes in good condition. This includes regularly checking the tread depth and pressure of the tires, and replacing them when necessary. It is also important to have the brakes checked and serviced regularly to ensure they are functioning properly and can effectively stop the car.
How can knowing the minimum stopping distance help with safe driving?
Knowing the minimum stopping distance of a car can help drivers maintain a safe distance from other cars on the road, especially in adverse weather conditions or when driving at high speeds. It also emphasizes the importance of maintaining a safe and legal speed while driving to ensure the car can come to a complete stop in case of an emergency.
10K
