Find n in Perfect Square
  • MHB
  • Thread starter Albert1
In summary, a perfect square is a number that can be expressed as the product of two equal integers and is the square of a whole number. To find the perfect square of a number, you simply multiply that number by itself. The formula for finding n in a perfect square is n = √x, where x is the perfect square number. A number is a perfect square if its square root is a whole number, which can be determined using a calculator or by finding the factors of the number. Negative numbers cannot be perfect squares as they always result in a positive number when multiplied by itself.
Albert1
1,221
$n\in N$ and $n^5+2n^4+2n^3+2n^2+2n+1$ is a perfect square
find $n$
Mathematics news on Phys.org
find $n$
hint:
$n^4+n^3+n^2+n+1$ is a perfect square , $n=?$
$(n\in N)$
My solution
we have $n^5+2n^4+2n^3+2n^2+2n+1= (n+1)(n^4+n^3+n^2+n+1)$
now $n+1$ and $(n^4+n^3+n^2+n+1$ are co-primes as $n^4+n^3+n^2+n+1 = (n+1)(n^3 + n) + 1$
so $(n+1)$ and $(n^4+n^3+n^2+n+1$ have to be perfect squares.
let us check for $(n^4+n^3+n^2+n+1$ find n and then check for n+ 1
We multiply by 16 to make it fraction free
$16(n^4+n^3+n^2+n+1) = (4n^2+2n+1)^2 + (2n+3)^2 + 6> (4n^2+2n+1)^2$
$16(n^4+n^3+n^2+n+1) = (4n^2+2n+2)^2 - 4(n+1)(n-3) < (4n^2+2n+2)^2$ for n not in [-1,3].
and $> 4n^2+2n+2)^2$ for n in $[-1,3]$
checking for n between [1,3] we see that it is a perfect square for n 3. as n is natural number
so n = 3 and n+1 is $2^2$
so only n that satisfies the condition is $n=3$ and for $n=3$ given expression is 484 or $22^2$
FAQ: Find n in Perfect Square
What is a perfect square?
A perfect square is a number that can be expressed as the product of two equal integers. In other words, it is the square of a whole number.
How do you find the perfect square of a number?
To find the perfect square of a number, you simply multiply that number by itself. For example, the perfect square of 4 is 4 x 4 = 16.
What is the formula for finding n in a perfect square?
The formula for finding n in a perfect square is n = √x, where x is the perfect square number. This means that n is the square root of x.
How do you determine if a number is a perfect square?
A number is a perfect square if its square root is a whole number. You can use a calculator to find the square root, or you can manually calculate it by finding the factors of the number.
Can negative numbers be perfect squares?
No, negative numbers cannot be perfect squares. Perfect squares are always positive numbers because when multiplied by itself, a negative number will result in a positive number.
