Find Nth Term of Sequence: (-1)^n
In summary, finding the nth term of a sequence is a complex problem with infinitely many possible nth term representations and an infinite number of sequences with a given initial finite segment.
scottshannon
46
I have been trying to find the nth term of the following sequence:
-1, 5, -17, 65...
I am thinking that the nth term has (-1) ^n . It doesn't appear to be a geometric or arithmetic sequence. I am stymied.
-1, 5, -17, 65...
It seems if $a_n = (-1)^{n-1} (4^{n}+1) \,\,\,\, n\geq 1$
ZaidAlyafey said:
It seems if $a_n = (-1)^{\color{red}{n}} (4^{\color{red}{n-1}}+1) \,\,\,\, n\geq 1$
correction
Thank you very much
skeeter said:
correction
why ? If $n=1$ then you get $a_1 = -2$.
yes you are correct..i overlooked that...
I wonder if anyone might have any further ideas? This nth term formulation gives all terms except the first.
-1, 5, -17, 65...
If the first number has index 1, then these numbers are described by the following formula.
a_n=
\begin{cases}-1&n=1\\
(-1)^n (4^{n-1}+1)&n>1
\end{cases}\qquad(*)
The sequence (*) is also described by infinitely many other formulas. Also, there are infinitely many sequences that start with -1, 5, -17, 65…, and each is described by infinitely many formulas.
"Also, there are infinitely many sequences that start with -1, 5, -17, 65…, and each is described by infinitely many formulas. "
Wow..I had no idea. There are a couple of things that had never occurred to me:
1) That it is permissible to write the nth term this way.
2) Also that there might be infinitely many nth term representations for a series where only the first 4 terms are given. Is it valid then to say that as one sees more terms in the series that the number of possibilities for the nth term decreases? If it is true that there are an infinite number of ways of writing the nth term representation, then will every one of them give the same 5th, 6th...terms?
It is permissible in principle. So without any restrictions this problem is not interesting. One could write a formula
a_n=
\begin{cases}
-1&n=1\\
5&n=2\\
-17&n=3\\
65&n=4\\
a_n=1&n>4.
\end{cases}
It specifies a valid function from natural numbers to natural numbers, and its values for $n=1,\dots,4$ are as required.
A specific problem may impose restrictions on how the function (i.e., the sequence) is specified. For example, it is possible to require that the expression specifying $a_n$ uses only addition, subtraction, multiplication and division. Then one solution is $a_n=22 n^3-146 n^2+290 n-167$ (it does not even use division). You can verify that $a_n$ are as required for $n=1,\dots,4$.
It is also possible to ask for a shortest expression. This problem may be interesting, but I haven't seen something like it.
One can do something silly such as changing an expression $E$ to $E+1+\dots+1-1-\dots-1$ where all 1's cancel. Strictly speaking, this expression specifies the same function, but it is a different from $E$. But one can also use write expressions such that proving their equality to $(-1)^{n} (4^{n-1}+1)$ would require highly nontrivial mathematics.
In some sense, but it is still infinite. An infinite set $A$ may be a subset of another set $B$ and yet have as many elements as $B$.
For each sequence (function) there is an infinite number of formulas (expressions) that specify it. Also, there are infinitely many sequences with a given initial finite segment such as -1, 5, -17, 65.
a_n=
\begin{cases}
-1&n=1\\
5&n=2\\
-17&n=3\\
65&n=4\\
a_n=1&n>4.
\end{cases}
Thank you very much
FAQ: Find Nth Term of Sequence: (-1)^n
What is the formula for finding the nth term of the sequence (-1)^n?
The formula for finding the nth term of the sequence (-1)^n is (-1)^n. This means that for every value of n, the term will alternate between positive and negative.
How do I determine the value of the nth term in the sequence (-1)^n?
To determine the value of the nth term in the sequence (-1)^n, simply plug in the value of n into the formula (-1)^n. For example, if n is 3, the value of the 3rd term in the sequence will be (-1)^3, which equals -1.
What is the pattern in the sequence (-1)^n?
The pattern in the sequence (-1)^n is that every term alternates between positive and negative. The first term is positive, the second term is negative, the third term is positive, and so on.
Can I use this formula to find the nth term in any sequence?
No, this formula only works for the specific sequence (-1)^n. Other sequences may have different patterns and require different formulas to find the nth term.
How can I use the nth term in this sequence to predict future terms?
Since the formula for the nth term in the sequence (-1)^n is simply (-1)^n, you can easily plug in different values of n to predict future terms. For example, if you want to predict the 10th term, you would plug in n = 10 into the formula, giving you (-1)^10, which equals 1. Therefore, the 10th term in the sequence will be 1.
