Find Number b/w 1000-2000: Impossible Sum of Consec. Nums
  • MHB
  • Thread starter kaliprasad
  • Tags
    Numbers Sum
In summary, the conversation discusses finding a number between 1000 and 2000 that cannot be expressed as a sum of consecutive numbers, with an example given for sums of consecutive numbers. It is shown that if a number cannot be expressed in this form, it must be a power of 2 and thus cannot have any odd divisors. Therefore, the number between 1000 and 2000 that cannot be expressed in this form is 1024. This is proven by showing that any power of 2 cannot be expressed as a sum of consecutive integers, as it will always have an odd factor.
kaliprasad
MHB
1,335
Find the number between 1000 and 2000 that cannot be expressed as sum of (that is >1) consecutive numbers.( To give example of sum of consecutive numbers
101 = 50 + 51
162 = 53 + 54 + 55 )
and show that it cannot be done
Mathematics news on Phys.org
101 = 50 + 51
[sp]Suppose that $n$ is a multiple of an odd number, say $n = k(2p+1)$. Then \(\displaystyle n = \sum_{r=-p}^p (k+r)\), so that $n$ is a sum of consecutive integers.
[Note: In that sum, some of the terms may be negative. But if so, those terms will cancel with some of the positive terms, leaving an expression for $n$ as a sum of consecutive positive integers. For example, if $k = 2$ and $p=3$ then $n = k(2p+1) = 14$, and the above formula gives $14 = (-1) + 0 + 1 + 2 + 3 + 4 + 5$. After cancelling the $-1$ with the $+1$, that becomes $14 = 2+3+4+5$.]
So if number cannot be expressed as a sum of that form then it can have no odd divisors at all and must therefore be a power of 2. If the number lies between 1000 and 2000 then it has to be 1024.
To see that a power of 2 cannot be a sum of that form, notice that if such a sum has an odd number of terms, say $2p+1$ terms with the middle term being $k$, then the sum is $k(2p+1)$ (as above) and therefore has an odd factor. If the sum has an even number of terms, say $2k$ terms starting with $m$, then the sum is \(\displaystyle \sum_{r=0}^{2k-1}(m+r) = k(2m+2k-1),\) which again has an odd factor, $2(m+k)-1.$ Therefore a power of 2 can never be a sum of consecutive integers.[/sp]
Good solution above by opalg.
my solution
for it to be a sum of consecutive numbers it must have an odd factor
Let N be a number that can be represented as a sum of k > 1 consecutive integers, starting with, let's say, a+1, summing the arithmetic progression, we get:
$N = (a+1) + (a+2) + (a+3) + . . + (a+k) = \frac(ka + k(k + 1)){2}$
Hence $2N = 2ka + k(k + 1) = k(2a + k + 1)$
Now if k is odd, N is divisible by k
If k is even, then 2a + k + 1 are odd and again N would have at least one odd factor.>1
Then I need to show that if it has a odd factor > 1 this can be expressed as sum of of consecutive number
2n + 1 = n + (n+1)
Any even number is a power of 2 or can be expressed as power of 2 multiplied by an odd number >1
Say it is $2^p(2n+1)$ where p is highest power of 2 which is a factor.
Now 2n+1 can be written as n+ (n+1) of course n > 1
Now we have 2 cases $2^p \lt n$ or $2^p \gt n$
Case 1) $2^p < n$
This can occur $2^p$ times but there shall be $2^p$ copies of n and $2^p$ copies on n + 1
In the kth copy subtract k-1 from n and add k-1 to n+ 1
So we get the values $n-(2^p-1)$ to $n+ 2^p$
The sum shall be $2^p ( n + 1 +n)$
And all numbers are consecutive ( 1st number >= 1) and positiveCase 2) $2^p > n$
We take 2n+1 copies of $2^p$
From the middle value at a distance of k we subtract k on from the left element and add k on the right element
So we have consecutive numbers $2^p-n$ to $2^p+ n$
Hence for it not to be sum of consecutive numbers it has to be power of 2 that is 1024
FAQ: Find Number b/w 1000-2000: Impossible Sum of Consec. Nums
Can a number between 1000-2000 be written as the sum of consecutive numbers?
Yes, a number between 1000-2000 can be written as the sum of consecutive numbers. However, there are certain constraints that need to be met for this to be possible.
What are the constraints for finding a number between 1000-2000 as the sum of consecutive numbers?
The first constraint is that the number must be even. This is because the sum of consecutive odd numbers will always result in an odd number, which cannot be in the range of 1000-2000. The second constraint is that the number must have an odd number of factors. This is because the sum of consecutive numbers will always result in an integer with an odd number of factors.
Why is it impossible to find a number between 1000-2000 as the sum of consecutive numbers if it does not meet the constraints?
If the number does not meet the constraints, then it cannot be written as the sum of consecutive numbers. This is because the sum of consecutive numbers will always result in an integer with an odd number of factors, and if the number does not have an odd number of factors, then it cannot be written as the sum of consecutive numbers.
Are there any strategies or methods to find a number between 1000-2000 as the sum of consecutive numbers?
Yes, there are strategies and methods to find a number between 1000-2000 as the sum of consecutive numbers. One way is to start with the smallest possible sum of consecutive numbers (e.g. 1+2) and keep adding consecutive numbers until the sum is within the range of 1000-2000. Another strategy is to use the formula for the sum of consecutive numbers, which is n(n+1)/2, and solve for n to find the consecutive numbers that add up to the desired number.
Is there a limit to the number of consecutive numbers that can be used to find a number between 1000-2000 as the sum of consecutive numbers?
Yes, there is a limit to the number of consecutive numbers that can be used to find a number between 1000-2000 as the sum of consecutive numbers. This limit is determined by the number itself, as the number of consecutive numbers that can be added to reach the desired number is equal to half of the number's odd factors. For example, if the number is 1200, it has 8 odd factors and therefore, the maximum number of consecutive numbers that can be used is 4.
18K
