Find number of moles of HCl to change pH of Histidine buffer.
In summary: I thought that the number of moles of OH- would be different because it would be adding something to the equation (i.e. going from a-->b). Am I misunderstanding something?
Sprinkles
There is 400 mL of 0.2 M histidine buffer- pH 11. Find the moles of HCl that are needed to change the pH to 3.2.
pH= pKa+log/[a]
First, this is how you would go from acid to base (acid-->base):
1. There is 400 mL of 0.2 M histidine buffer- pH 3.2 Find the moles of OH that are needed to change the pH to 11.
H+2 <--> H+1 <-->H0 <-->H-1
1) Find a and b using H-H, and pKa values (2.1-pKa of COOH and 3.2 in one equation, and 9.6-pKa of NH3+ and 11 in the second equation).
ADD PLUS ONE. (H+1<---->H0)
a+b+1= total1) [This total is the total # of equivalents.]
2) Multiply .4 L by 0.2 M.=total2)
3) Multiple total1) and total2) together to get the final answer.Now my question:
What if we had to go backwards- from base to acid?
There is 400 mL of 0.2 M histidine buffer- pH 11. Find the moles of HCl that are needed to change the pH to 3.2.Would I subtract -1 now? (Please see 1).) I am just confused on how to go backwards (base to acid). How should the number change? When going from a-->b you need moles of OH- to increase the pH, but from b-->a you would need moles of HCl to decrease the pH, so the number of moles should be different, I assume. However, when calculating it, I get the same number of moles for both H+ and OH-. Thank you!Thank you!
pH= pKa+log/[a]
Now my question:
Thank you!
Thank you!
If I understand your question I don't understand your perplexity - the number of moles should be exactly the same both ways.
Also please check back the question. Histidine has another ionising group of pK about 6 you have not mentioned.
Offhand on a quick look you ought to realize that the answer has to be quite close to 2 moles added base per mole of histidine, probably more important than the exact number - is that what you got?
^Thank you so much epenguin! I appreciate your time. Let me explain my reasoning in a different way:
We're trying to find the number of moles of HCl that are required to change the pH from 11 to a pH of 3.2 (of this Histidine buffer solution).
We would still need to do two H-H equations (1st H-H: use pKa of COOH, 2.1 and pH, 3.2 / 2nd H-H: use pKa of NH3+, 9.6 and pH 11). Find "a" by using the 1st H-H ("a"=.07359), and find "b" using the 2nd H-H ("b"=.9693).
The total number of moles of Histidine= 0.4 L x 0.2 M= 0.08 moles of Histidine
[*Assuming that the addition of acid doesn't interfere w/volume of solution.*]To find the total number of moles of H+ = (a=acid)(moles of histidine) + (b=base)(moles of histdine) (+/-) ( ______ )
(.07359)(0.08) + (.9693)(0.08) (+ or -) _______
I'm getting stuck with the last blank. Would I subtract or add 0.08 now?To find the moles of OH- needed to change pH from 3.2 to 11, you would add another 0.08 moles of Histdine (in that last blank).
So, to find the moles of H+ needed to change pH from 11 to 3.2, does this mean that you need to subtract 0.08 moles of Histidine?
I am getting confused, because I get the same answer for both the number of moles of OH- needed to go up the curve, and for the number of moles
of H+ needed to go down the curve. My reasoning is because it's all along the same curve, and it's an equilibrium.In terms of ionizable groups, this is the equation that I have:
His+2 <---> His+1 <---->His0 <----> His-1
(pKa of COOH 2.1)-->inbetween His +2 and His+1
(pKa of Histidine 6.0) --> inbetween His +1 and His 0
(pKa of NH3+ 9.6)-->inbetween His0 and His-1
To avoid complication of inessentials I’ll take a case of 1l of 1M solutions.
Just take the case of a simple base RNH2. At pH 3.2 error is totally negligible in assuming it 100% RNH3+. To go to high pH you have to add 1 mole of NaOH. To go to only pH 11 you add instead a bit less, roughly 0.96 moles. So you’ll have in your solution about 0.96 M RNH2 AND 0.04 M RNH3+, exact amount calculate by HH equation.
To get back to pH 3.2 you’ll have to add the same amount, 0.96 moles say, of HCl! What you’re really doing is reacting your RNH2 with H+ to reprotonate them. But along with the H+ you have to add Cl-.
(I guess the confusing thing about these calculations is that the H+ which is the concentration usually of interest is such a small fraction of the ions present that for some parts of the calculation you ignore it, you ignore the thing that is of interest!)
This principle is still the same however many ionisations there are, however complicated the scheme. The moles of strong base you add to increase the pH from x to y = amount of strong acid to decrease from y to x.
In your case you have to add 1 mole in going from pH 3.2 to 11 to get your imidazole group of histidine from totally protonated to totally unprotonated (well below to well above the pK). You seem on second reading to be perhaps aware of this.
There is additionally a bit less than 1 mole of base to be added to nearly deprotonate the RNH3+ as explained above.
On the other hand at pH 3.2, there is a small fraction of the carboxyl group still protonated. I think this will be about 0.08 M. So you will have to add a corresponding extra amount of base to deprotonate this.
So yes the answer to your question is the two effects are opposite, there will be a subtraction, not addition.
I hope this is not additionally confusing (I see now I have done the inverse problem by should be OK) and that it helps you think your way through.
The scheme is HOOC-Im+-NH3+ [itex]\Leftrightarrow[/itex] -OOC-Im+-NH3+ [itex]\Leftrightarrow[/itex] OOC-Im-NH3+ [itex]\Leftrightarrow[/itex] -OOC-Im-NH2
(left out the loose protons).
epenguin said:
1) This principle is still the same however many ionisations there are, however complicated the scheme. The moles of strong base you add to increase the pH from x to y = amount of strong acid to decrease from y to x.
2) So yes the answer to your question is the two effects are opposite, there will be a subtraction, not addition.
Thank you so much for that explanation! I'm not really advanced in pH/buffer questions, so it's a tad confusing, but I still appreciate your reply. So in 1) you're saying that 0.08 moles of histidine will always be the case for both when you're going up the pH and down?
and by 2) you mean that it would look like this:
The total number of moles of HCl that are required to change the pH from 11 to a pH of 3.2 (of this Histidine buffer solution)=
(a=acid)(moles of histidine) + (b=base)(moles of histidine) - (moles of histidine)
(.07359)(0.08) + (.9693)(0.08) - 0.08
At pH of 3.2, histidine has a net charge of +1.
versus
There is 400 mL of 0.2 M histidine buffer- pH 3.2 Find the moles of OH- that are needed to change the pH to 11.
Where this would be: (.07359)(0.08) + (.9693)(0.08) + 0.08 <----This is the correct answer when going from
acid to base (pH 3.2 to pH 11).
At pH 11, histidine has a net charge of 0.
The equilibria written better:
HOOC-ImH+-NH3+ [itex]\Leftrightarrow[/itex] -OOC-ImH+-NH3+ [itex]\Leftrightarrow[/itex] -OOC-Im-NH3+ [itex]\Leftrightarrow[/itex] -OOC-Im-NH2
Net charges: +2, +1, 0, -1
If I understand the question, yes, I confirm.
You can also think of it like this. If I add a number of moles NaOH upping the pH then the same number moles HCl going down I get to the pH I started. If these numbers are equal, it is like I added NaCl - which is 'neutral' and doesn't change pH. Conversely if they are not equal it is like I added some acid or alkali which does change the pH
Most of it. About 0.0735 of it has charge +2 in accord almost with your calc. But the fractions have to add up to 1 so I get 0.927 of it is n the +1 form.
versus
Most of it is -1 I think you meant. I get that 0.962 of it is in that form, nearly in accord with your figure, 0.0383 of it is the 0 form. Again your figs. Do not stack up to 1 maybe you have mixed some up.
More useful almost than exact calculations are rough ones that help you see where you are and what is happening or should be.
So remember that if you are 1 pH unit away from the pK you are getting out out of the buffering zone, the unfavoured form is about 10% of the total, 2 units away it is near 1%, 3 units, 0.1% and so on. From that you could have guessed roughly about how much the fractions mentioned were. Also from that you can see that at pH 3.2 there is so little of the 0 and -1 forms you can ignore them, while at pH 11 you can ignore the +1 and +2 forms.
So, we maybe saying the same thing in different ways, to get from pH 11 to 3.2 (1l 1M total histidine) you will be adding a bit less of than a mole, 0.96 moles, of HCl to protonate the amino group of the not quite total -1 form that there is, 1 mole to protonate the imidzole group that brings you to the +1 form and then 0.038 mole to get the small fraction of +2 that there is at pH 3.2, I make it just over 2: 2.036. I expected it very close to 2.
At end just multiply by your 0.08 to change it to your volume and concentration
^Thank you so much for the reply, epenguin! :)
I appreciate the time that you spent, and the help that you have provided.
Happy Holidays!
Related to Find number of moles of HCl to change pH of Histidine buffer.
1. How do I calculate the number of moles of HCl needed to change the pH of a histidine buffer?
To calculate the number of moles of HCl needed, you will need to know the initial pH of the buffer, the desired pH, the volume of the buffer, and the concentration of the HCl solution. You can then use the Henderson-Hasselbalch equation to determine the number of moles of HCl needed to change the pH of the buffer.
2. What is the Henderson-Hasselbalch equation and how does it relate to changing the pH of a buffer?
The Henderson-Hasselbalch equation is a mathematical equation that relates the pH of a buffer solution to the pKa and the concentrations of the acid and conjugate base components of the buffer. This equation can be used to determine the number of moles of acid needed to change the pH of a buffer solution.
3. Can I use any concentration of HCl to change the pH of a histidine buffer?
No, the concentration of HCl used must be carefully chosen to prevent overshooting the desired pH. You will need to use the Henderson-Hasselbalch equation to calculate the appropriate concentration of HCl needed to achieve the desired pH change.
4. What is the importance of maintaining a specific pH in a histidine buffer solution?
Histidine buffer solutions are commonly used in biochemical experiments because they closely mimic the pH of biological systems. Maintaining a specific pH in these buffer solutions is crucial for accurate and reproducible results, as many biological processes are pH-dependent.
5. Are there any other factors that could affect the number of moles of HCl needed to change the pH of a histidine buffer?
Yes, there are other factors that can affect the number of moles of HCl needed, such as temperature, ionic strength, and the presence of other chemical compounds in the buffer solution. It is important to carefully consider and control these factors when calculating the number of moles of HCl needed to change the pH of a histidine buffer.
