Find out a function R--> R such that it is integrable
  • Thread starter ss_1985
  • Tags
    Function
In summary, the conversation discusses finding a function in the domain R-->R that is integrable but its square is not. The suggested function, f(x)=1/\sqrt{x}, is not correct as the integral of 1/\sqrt{x} over the interval from negative infinity to infinity does not exist. The speaker asks for a hint to solve the problem.
ss_1985
Hi
The question asks to find out a function R--> R such that it is integrable, and its square is not.
Is f(x)=1/root x right?
The problem I thought was its only over an interval
Please help
thanks
ss_1985 said:
Hi
Please help
thanks
No, [itex]1/\sqrt{x}[/itex] is not correct because
[tex]\int_{-\infty}^{\infty}\frac{dx}{\sqrt{x}}[/tex]
does not exist.
Can you give me a hint?
FAQ: Find out a function R--> R such that it is integrable
What is an integrable function?
An integrable function is a mathematical function that can be represented by an integral, which is a mathematical operation that can be used to calculate the area under a curve. In simpler terms, an integrable function is one that can be easily integrated or "added up" to find a total value.
What does R-->R mean in the context of a function?
R-->R refers to a function that takes a real number as an input and returns a real number as an output. In other words, the function operates on real numbers and produces real numbers as a result.
Can you give an example of an integrable function?
One example of an integrable function is f(x) = x^2. This function can be easily integrated to find the area under the curve, which in this case, is the area of a parabola. The integral of f(x) = x^2 is x^3/3 + C, where C is a constant.
What makes a function integrable?
A function is considered integrable if it meets certain criteria, such as being continuous and bounded on a given interval. This means that the function is defined and has a finite value at every point within the interval. Additionally, the function must also have a finite number of discontinuities within the interval in order to be integrable.
Can you explain the importance of integrable functions in science?
Integrable functions are essential in many areas of science, particularly in physics and engineering. They are used to calculate various physical quantities, such as work, energy, and momentum, and are also crucial in solving differential equations, which are commonly used to model natural phenomena. In addition, integrable functions play a key role in the development of advanced mathematical techniques and theories, making them a fundamental concept in the field of science.
