Find Parameter Producing Line l Through Points P and Q
  • MHB
  • Thread starter Petrus
  • Tags
    Parameter
In summary, Petrus is asking for help with understanding how to find a parameter that produces a line through two given points in a specific example from his book. The conversation also includes a request for translations from Swedish to English and a statement about the importance of providing meaningful posts for all members. In the end, Petrus solves the problem on his own.
Petrus
702
Hello MHb,
Decide one parameter producing for line l through the points \(\displaystyle P=(1,1,2)\) and \(\displaystyle Q=(2,-3,5)\)
This is a exempel from my book, I understand how they got the first line but not the second, (I hope that it don't mather it's on Swedish)
Regards,
\(\displaystyle |\pi\rangle\)
Re: parameter producing
Petrus said:
...(I hope that it don't mather it's on Swedish)...
Hey Petrus,
Actually, it would be helpful if you translated the text in Swedish to English. Most of our members do not speak or read Swedish, and while mathematics is universal, the explanatory statements are meant to supplement the mathematical expressions, that is, to explain the reasoning behind them. So, in an effort to provide the most meaningful post to our members, you should translate everything into English.
While it may be easier for you not to translate, it then requires more effort on the part of those trying to help, and it should be the other way around. (Wink)
MarkFL said:
Hey Petrus,
Solved it :D Sorry about that, I am just repeats to my exam that is in few days so i am kinda stressed :P But I solved it:)
Regards,
FAQ: Find Parameter Producing Line l Through Points P and Q
How do I find the parameter producing a line through points P and Q?
The parameter producing a line through points P and Q can be found by using the slope formula in the form of (y2-y1)/(x2-x1). The resulting value will be the parameter that can be used to represent any point on the line.
What information do I need to find the parameter producing a line?
To find the parameter producing a line, you will need the coordinates of the two points, P and Q, that the line passes through. This will allow you to calculate the slope and determine the parameter.
Can I find the parameter producing a line through more than two points?
Yes, you can find the parameter producing a line through more than two points. However, you will need to choose two of the points to use as your reference points and then calculate the slope and parameter using those two points.
Is the parameter the same as the slope?
No, the parameter is not the same as the slope. The slope is a measure of the steepness of a line, while the parameter is a value that represents a point on the line. However, the two are related, as the slope is used to calculate the parameter.
Can I use the parameter to determine the equation of a line?
Yes, you can use the parameter to determine the equation of a line. Once you have the parameter, you can plug it into the equation y = mx + b, where m represents the slope and b represents the y-intercept, to get the equation of the line.
