MHB Find Point E in Harmonic Range with A, B, C using Cross Ratio -1
  • Thread starter Thread starter Poirot1
    Cross Ratio
Poirot1
A=$\begin{bmatrix}1\\1\\0\end{bmatrix}$, B=$\begin{bmatrix}3\\1\\-1\end{bmatrix}$
C=$\begin{bmatrix}5\\3\\-1\end{bmatrix}$, D=$\begin{bmatrix}4\\0\\-2\end{bmatrix}$
Find the coordinates of a point E such that A,B,C,E forms a harmonic range. This means that the cross ratio is -1.
Hi Poirot, :)
Let, \(E\equiv (x,y,z)\). Write down the cross ratio considering the \(x\), \(y\) and \(z\) coordinates of the points \(A\), \(B\), \(C\) and \(E\). For example,
\[(A,B,C,E)=\frac{AC}{BC}: \frac{AE}{AB}=\frac{1-5}{3-5}:\frac{1-x}{1-3}\]
Since \(A\), \(B\), \(C\) and \(E\) are in harmonic range, \((A,B,C,E)=-1\). Therefore,
\[(A,B,C,E)=\frac{1-5}{3-5}:\frac{1-x}{1-3}=-1\]
Find \(x\). Similarly you can also find \(y\) and \(z\). More information about Cross ratios can be found http://www.ping.be/math/cross.htm#Dividing-ratio.
Kind Regards,
Sudharaka.
There is something puzzling about this question. A harmonic range is normally only defined for four collinear points. If you have three collinear points then you can find a fourth point on the line making up a harmonic range, using the method described by Sudharaka. But in this problem the three given points are not collinear. You can easily see this because the points $A$ and $B$ have the same $y$-coordinate 1, but $C$ has $y$-coordinate 3. If the points were collinear that could not happen.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
