Find Point in R2: $a(-5,2),b(12,9)$
  • MHB
  • Thread starter Amer
  • Tags
    Point
In summary, we are given two points in $\mathbb{R^2}$, $a(-5,2)$ and $b(12,9)$, and we need to find a point $c$ that satisfies the conditions $ac = bc$ and $ac \perp bc$. Using the fact that the set of points equidistant from $a$ and $b$ lies on the perpendicular bisector of $ab$, we can solve for $c$ by setting up and solving two equations. Another method is to draw a diagram and use geometry to find the two possible positions for $c$, which are $(0,14)$ and $(7,-3)$.
Amer
259
Let $a(-5,2),b(12,9)$ be two points in $\mathbb{R^2}$ find a point $c\in \mathbb{R^2}$ such that
$ac = bc$ and
$ac \perp bc$
I have a long solution I made two equations ( I considered $c (x,y)$ )
$$ ac = bc $$
$$ \sqrt{ (x +5)^2 + (y-12)^2 } = \sqrt{(x -12)^2 + ( y - 9)^2 }$$
and
$$ \frac{y-9}{x-12} \cdot \frac{y-2}{x+5} = -1 $$
and solve them by substitution
is there any faster solution shorter ?
Thanks in advance.
Mathematics news on Phys.org
$ac = bc$ and
$ac \perp bc$
$$ ac = bc $$
and
Thanks in advance.
That solution looks fine (and not really too long). An alternative method would be to draw a diagram and do some geometry.
The set of points equidistant from $a$ and $b$ is the perpendicular bisector of $ab$. So $c$ must lie on that line. In fact, there are two possible positions for $c$, I'll call them $c_1$ and $c_2$.
The other condition, $ac \perp bc$, implies that the points $a,c_1,b,c_2$ are the vertices of a square centred at the midpoint of $ab$, $(3.5,5.5)$. The vector from there to $b$ is $(12,9) - (3.5,5.5) = (8.5,3.5)$. A perpendicular vector of the same length is $\pm(-3.5,8.5)$. So the possible positions for $c$ are $(3.5,5.5) \pm (-3.5,8.5)$. That gives $c_1 = (0,14)$ and $c_2 = $(7,-3)$.
Great solution thanks :)
FAQ: Find Point in R2: $a(-5,2),b(12,9)$
What is the formula for finding the midpoint of two points in R2?
The formula for finding the midpoint of two points in R2 is (x1+x2)/2, (y1+y2)/2. This means you add the x-coordinates of the two points and divide by 2, then add the y-coordinates and divide by 2 to find the coordinates of the midpoint.
How do you find the distance between two points in R2?
The distance between two points in R2 can be found using the Pythagorean theorem, which is d = √((x2-x1)^2 + (y2-y1)^2). This means you square the difference between the x-coordinates, square the difference between the y-coordinates, add them together, and then take the square root to find the distance.
What is the x-coordinate of the midpoint between points $a(-5,2)$ and $b(12,9)$?
The x-coordinate of the midpoint between points $a(-5,2)$ and $b(12,9)$ is (12+(-5))/2 = 3.5. This means the x-coordinate of the midpoint is 3.5.
What is the y-coordinate of the midpoint between points $a(-5,2)$ and $b(12,9)$?
The y-coordinate of the midpoint between points $a(-5,2)$ and $b(12,9)$ is (9+2)/2 = 5.5. This means the y-coordinate of the midpoint is 5.5.
What is the distance between points $a(-5,2)$ and $b(12,9)$?
The distance between points $a(-5,2)$ and $b(12,9)$ can be found using the Pythagorean theorem: d = √((12-(-5))^2 + (9-2)^2) = √(17^2 + 7^2) = √(289+49) = √338 ≈ 18.38. This means the distance between the two points is approximately 18.38.
