MHB Find position vector using midpoint of two other vectors
To find the position vector of point R, which is the midpoint between points P and Q with position vectors p and q, the correct expression is r = (p + q) / 2. The original poster expressed confusion about converting points into position vectors, but the solution simplifies to averaging the two vectors. The discussion emphasizes that the problem is straightforward and can be resolved with basic vector operations. Overall, the midpoint formula effectively provides the desired position vector.
TheFallen018
Hi, I've got this problem I'm trying to work out. The problem seems simple, but I don't think I have a good way to construct a way to solve it.
This is the problem.
Let P and Q be two points with position vectors p and q and let
R be a point midway between these two. Find an expression for
the position vector r of R in terms of p and q.
So, the midpoint of P and Q should be \[R=\frac{P+Q}{2}\], however I'm not sure how to turn each of these things into position vectors. Any help would be great. Thanks
Mathematics news on Phys.org
unless I'm missing something, it seems that you're making this more difficult than it really is ...
$\vec{r} = \dfrac{1}{2}(\vec{p}+\vec{q})$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
