Find potential energy using time-independent Schrodinger's equation
The discussion revolves around determining the potential energy function U(x) using the time-independent Schrödinger equation. The derived expression for U(x) is (2h^2/mL^4)(x^2 - 3L^2/2), which indicates a parabolic shape centered at x = 0. The solution key confirms that U(0) equals −3h^2/mL^2, suggesting that plugging in x = 0 yields the correct value for U(x). The participants clarify that the parabolic nature of U(x) is evident from its quadratic form. Understanding these aspects is crucial for accurately interpreting the potential energy in quantum mechanics.
eloiseh
In a region of space, a particle with mass m and with zero energy has a time-independent wave function ψ(x) = Axe^(−x^2/L^2) where A and L are constants.
Determine the potential energy U(x) of the particle.
The time-independent Schrodinger's equation
I had found what U(x) was equal to already by plugging in the wave function and simplifying, which is (2h^2/mL^4)(x^2 - 3L^2/2) by the way.
But the solution key that I have goes an extra step. After stating the equation of U(x) that I got, it says that: "U(x) is a parabola centred at x = 0 with U(0) = −3h^2/mL^2"
Does that mean that I have to plug 0 in for x for the right answer? And how to determine that U(x) is a parabola centred at x=0?
Your solution is a parabola centred at ##x=0##.
Thank you so much!
  • · Replies 19 ·
