MHB Find Price Elasticity of Demand
  • Thread starter Thread starter mathkid3
    Elasticity
To find the price elasticity of demand for the function p = (500)/(x^2) + 5 at x = 5, first compute the derivative dp/dx and evaluate it at x = 5. Then, calculate p(5) and divide it by 5 to find the necessary values for the elasticity formula N = (p/x)/(dp/dx). The demand is classified as elastic, inelastic, or unit elastic based on whether the absolute value of N is greater than, less than, or equal to 1, respectively. Clarifications on the calculations and definitions of elasticity were discussed, emphasizing the importance of accurate interpretation of the formulas.
mathkid3
Find price elasticity of demand for the demand function at the indicated x-value.
Is the demand elastic, inelastic or of unit elasticity at the indicated x-value?
Use a graphing utility to graph the revenue function, and identify the intervals of elasticity and inelasticity. ... I will list all information I can to help someone to help me to solve and understand the problem.
Demand Function = p = (500)/(x^2) + 5
x-value = 5
The following may be of help as well...
Definition of Price Elasticity of Demand - If p = f(x) is a differentiable function, then the price elasticity of demand is given by
N = (p/x)/(dp/dx)
where N is the lowercase Greek letter eta. For a given price, the demand is elastic when abs(absolute) value N > 1, the demand is inelastic when abs N < 1, and the demand has unit elasticity when abs N = 1Thanks in advance for any and all assistance on this Calculus problem
-mathkid3 (Happy)
Mathematics news on Phys.org
Well, I would begin by computing $\displaystyle \frac{dp}{dx}|_{x=5}$
Next, I would compute $\displaystyle \frac{p(5)}{5}$.
Once you have these two numbers, then compute their quotient to get the price elasticity of demand $\displaystyle \eta$.
Now, let's see what you get...
By the way, this site also supports the rendering of $\displaystyle \LaTeX$. The difference is (at least the way I do it) is to enclose your code with the tags:
Code:
$\displaystyle insert code here$
Mark,
so glad you are on this site and you have already helped me so much with understanding some of these Calculus problems.
ok ..let's see...
You said first to find the derV of p so I get
(x-1000)/(x^3)
next you say find p(5)/(5)
Areyou saying to plug 5 into the original function and then divided the outcome by 5?
if so I get x = 5
am I correct thus far and if so tell me again what to do next?
If I am not correct, would you explain to me again what to do ?
Thank You
N = (p/x)/(dp/dx)
Your definition of elasticity:
\[E_d=\frac{p}{x \frac{dp}{dx}}\]
is the reciprical of that given on the Wikipedia page linked to in your other thread:
\[E_d=\frac{x}{p}\frac{dp}{dx}\]
(Note that the Wikipedia page uses \(Q\) for demand (quantity) and \(P\) for price).
Now the table the Wikipedia page gives for interpreting \(E_p\) is exactly the same as that given above by you, so there is a mistake somewhere.
CB
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
