Find principal value in a+ib form.
  • MHB
  • Thread starter paulbk108
  • Tags
    Form Value
In summary, the principal value in a+ib form is a way of representing complex numbers, where 'a' represents the real part of the number and 'ib' represents the imaginary part of the number. To find the principal value in a+ib form, the real and imaginary parts of the complex number must be identified and combined using the formula a+ib. This differs from the polar form, where the number is expressed as r(cosθ + isinθ). The principal value in a+ib form can be negative, indicating the location of the complex number in the third or fourth quadrant of the complex plane. It is commonly used in mathematics and science to manipulate and solve problems involving electrical circuits, quantum mechanics, and signal processing.
paulbk108
I need to find principal value of (1-i)^2i.
Let z = 1 - i
z^a = e^(a*lnz)
=e^2i*ln(1-i)
r = z = sqrt(1^2 + (-1)^2 = sqrt(2)
tan theta = y/x = -1/1 = -1 => theta = argz = -45 degrees = -pi/4 rads.ln z= loge(z) = i(theta + 2*pi*n)
= loge(sqrt(2)) + i(-pi/4 + 2*pi)
= loge(sqrt(2)) - i*pi/4
Could someone please help me out here finishing this one off - into a + ib form? Struggling a little with completion.
Much appreciated if you could.Regards.
Let z = 1 - i
z^a = e^(a*lnz)
=e^2i*ln(1-i)
You are correct to this point.
$\exp \left[ {2i\log \left( {1 - i} \right)} \right] = \exp \left[ {2i\left( {\ln (\sqrt 2 ) - i\frac{\pi }{4}} \right)} \right]$
And then?
I know e^z = e^(x + iy) = e^x(cosy + isiny).
Is x simply 2i*ln(sqrt(2)) and y 2i*(i*pi/4) ?Regards.
Write $ {2i\log \left( {1 - i} \right)}$ in the $a+bi$ form.
If $z=\exp(a+bi)$ then $x=e^a\cos(b)~\&~y=e^x\sin(b)$.
Let z = 1 - i
z^a = e^(a*lnz)
=e^2i*ln(1-i)
\[ \displaystyle \begin{align*} (1 - i)^{2i} &= \left(2^{\frac{1}{2}}e^{-\frac{\pi}{4}i}\right)^{2i} \\ &= \left(2^{\frac{1}{2}}\right)^{2i}\left(e^{-\frac{\pi}{4}i}\right)^{2i} \\ &= 2^ie^{\frac{\pi}{2}} \\ &= e^{\log{\left(2^i\right)}}e^{\frac{\pi}{2}} \\ &= e^{i\log{2}}e^{\frac{\pi}{2}} \\ &= e^{\frac{\pi}{2}}\left[\cos{\left(\log{2}\right)} + i\sin{\left(\log{2}\right)}\right] \\ &= e^{\frac{\pi}{2}}\cos{\left(\log{2}\right)} + i\,e^{\frac{\pi}{2}}\sin{\left(\log{2}\right)}
\end{align*} \]
Can you please explain where you got the 2^1/2 from?
My textbook goes nowhere near explaining this material in depth. Frustrating...Regards.
---------- Post added at 10:04 PM ---------- Previous post was at 08:42 PM ----------
All good. Understood (finally:p).Thanks and regards.
It's the magnitude of 1 - i :)
FAQ: Find principal value in a+ib form.
What is the principal value in a+ib form?
The principal value in a+ib form is a way of representing complex numbers, where 'a' represents the real part of the number and 'ib' represents the imaginary part of the number.
How do you find the principal value in a+ib form?
To find the principal value in a+ib form, you need to first identify the real and imaginary parts of the complex number. Then, you can combine them using the formula a+ib, where 'a' is the real part and 'b' is the imaginary part.
What is the difference between the principal value and the polar form of a complex number?
The principal value in a+ib form is a rectangular representation of a complex number, while the polar form is a polar representation. In the polar form, the number is expressed as r(cosθ + isinθ), where 'r' is the distance from the origin and 'θ' is the angle of the number in the complex plane.
Can the principal value in a+ib form be negative?
Yes, the principal value in a+ib form can be negative. This indicates that the complex number is located in the third or fourth quadrant of the complex plane.
How is the principal value in a+ib form used in mathematics and science?
The principal value in a+ib form is commonly used in mathematics and science to represent and manipulate complex numbers. It is especially useful in solving problems involving electrical circuits, quantum mechanics, and signal processing.
