Find Product of 3 Real Numbers if System of Eqns Satisfied
  • MHB
  • Thread starter anemone
  • Tags
    Product
In summary, the product of three distinct real numbers $a, b, c$ is equal to $2$ if they satisfy the system of equations $a^3=3b^2+3c^2-25, b^3=3c^2+3a^2-25, c^3=3a^2+3b^2-25$. However, this solution is incorrect as it does not satisfy the given equations.
anemone
MHB
POTW Director
3,883
115
Find the product of 3 distinct real numbers $a, b, c$ if they satisfy the system of equations
$a^3=3b^2+3c^2-25$
$b^3=3c^2+3a^2-25$
$c^3=3a^2+3b^2-25$
Mathematics news on Phys.org
$a^3=3b^2+3c^2-25$
$b^3=3c^2+3a^2-25$
$c^3=3a^2+3b^2-25$
$a^3=3b^2+3c^2-25---(1)$
$b^3=3c^2+3a^2-25---(2)$
$c^3=3a^2+3b^2-25---(3)$
(1)+(2)+(3):
$a^3+b^3+c^3-6(a^2+b^2+c^2)+75=0$
$(a^3-6a^2+25)+(b^3-6b^2+25)+(c^3-6c^2+25)=0$
we can consider a,b,c as the solutions of equation :$x^3-6x^2+0x+25=0$
so abc=-25
(1)+(2)+(3):
so abc=-25
Thanks for participating, Albert but I'm afraid that your answer isn't correct...
Though I couldn't tell from your approach where it went wrong, I solved the cubic equation $x^3-6x^2+0x+25=0$solve x^3-6x^2+0x+25=0 - Wolfram|Alpha by using wolfram and when I back substituting them into any of the given three equations, the LHS's value isn't equal to the RHS's value.
And for your information, I get $abc=2$.
Here's my solution
If we pick any two and subtract, we can factor. Thus,
$(a-b)(a^2+ab+b^2+3a+3b)=0$
$(a-c)(a^2+ac+c^2+3a+3c)=0$
$(b-c)(b^2+bc+c^2+3b+3c)=0$
As $a, b$ and $c$ are distinct we have
$a^2+ab+b^2+3a+3b=0$
$a^2+ac+c^2+3a+3c=0\;\;\;(1)$
$b^2+bc+c^2+3b+3c=0$
Subtracting any pair again, we can factor
$(a-b)(a+b+c+3)=0$
$(a-c)(a+b+c+3)=0$
$(b-c)(a+b+c+3)=0$
Thus, $a+b+c +3 = 0\;\;\;(2)$
If we add the system of equations (1) and use (2) to eliminate terms we get
$ab + bc + ac = 0\;\;\;(3)$
Now we consider
$(a+b+c+3)^3 =0$
Using the original set of equations and equation (2) and (3) we are to arrive at $6-3abc = 0$ from which we find $abc = 2$
I did not solve a,b,c but
I also get ab+bc+ca=0 (from equation X^3 -6X^2 +25=0)
Can anybody tell me what is wrong with my solution ?
in fact a replaced by b,b replaced by c ,and c replaced by a
(1)(2)(3) are equivalent
Jester said:
Here's my solution
$(a-b)(a+b+c+3)=0$
$(a-c)(a+b+c+3)=0$
$(b-c)(a+b+c+3)=0$
Now we consider
$(a+b+c+3)^3 =0$
Or a=b= c which gives
a^3 = 3a^2 + 3a^2 – 25
or a^3 – 6a^2 + 25 = 0
this does not have 3 identical roots which is a contradiction
hence a = b = c is ruled out
so abc = 2 is the only solution
- - - Updated - - -
f(a) + f(b) + f(c) = 0 (here f(a) = a^3 – 6a^2 + 25) does not mean f(a) = f(b) = f(c) = 0
this is the mistake in above step of Albert
Hello Albert,
Though I have mentioned in one of above messge I thought to clarify as this question is asked
f(a) + f(b) + f(c) = 0 here f(a) = a^3 – 6a^2 + 25 does not mean f(a) = f(b) = f(c) = 0
(1)+(2)+(3):
so abc=-25
I think your method is fine but it's just that we need to check our final answer to see if it agrees with the given information.
I think you meant $a, b, c$ are three different real roots of the cubic equation $x^3-6x^2+0x+25=0$ and hence, adding the three equations $a^3-6a^2+25=0$, $b^3-6b^2+25=0$, and $c^3-6c^2+25=0$ together yields $a^3+b^3+c^3-6(a^2+b^2+c^2)+75=0$ which then implies the product of a, b, c be $-25$.
But if we check the result with the first given equation, namely $a^3=3b^2+3c^2-25$, it's not hard to see that if $a=b=c$, then we get $a^3-6a^2+25=0$ and this contradicts the condition where $a, b, c$ are three distinct real numbers and hence, we can conclude that you have got a wrong answer.
according to Jester's solution :
a+b+c=-3
ab+bc+ca=0
abc=2
then a,b,c is the solutions of equation :$x^3+3x^2-2=0$
and the solutions are :$-1, -1+\sqrt3 ,-1-\sqrt 3$
so I did not check my final answer to see if it agrees with
My solution:
We're given the three equations
$a^3=3b^2+3c^2-25$
$b^3=3c^2+3a^2-25$
$c^3=3a^2+3b^2-25$
Subtract the second one from the first one gives
$a^3-b^3=3b^2-3a^2$
$(a-b)(a^2+ab+b^2)=3(b-a)(b+a)$
Since $a \ne b$, we get
$a^2+ab+b^2+3a+3b=0$ which after rearranging to make $a^2+b^2$ the subject we have
$a^2+b^2=-3(a+b)-ab$ and
$a^2+c^2=-3(a+c)-ac$
$b^2+c^2=-3(b+c)-bc$
Adding the three equations above yields
$2(a^2+b^2+c^2)=-6(a+b+c)-(ab+bc+ac)$(*)
From the first equation, if we add $c^2$ to both sides of the equation we get
$a^2+b^2+c^2=-3(a+b)-ab+c^2$
$a^2+b^2+c^2=-3(a+b+c)+3c-ab+c^2$
$2(a^2+b^2+c^2)=-6(a+b+c)+6c-2ab+2c^2$(**)
Equating both equations (*) and (**) gives
$-6(a+b+c)-(ab+bc+ac)=-6(a+b+c)+6c-2ab+2c^2$
$6c-2ab+2c^2=-(ab+bc+ac)$
$2c^2+6c=-(ab+bc+ac)+2ab$
$2c^2+6c=ab-c(a+b)$
$2c^2+6c=ab-c(a+b+c)+c^2$
$c^2+6c=ab-c(a+b+c)$
$c^2+6c=\dfrac{abc}{c}-c(a+b+c)$
If we let $m=a+b+c$ and $k=abc$, the equation above becomes
$c^2+6c=\dfrac{k}{c}-cm$
$c^3+6c^2=k-c^2m$
$c^3+(6+m)c^2-k=0$
If we let $a, b, c$ be the three distinct real roots of a cubic function where $f(x)=x^3-(a+b+c)x^2+(ab+ac+bc)x-abc$ or $f(x)=x^3-mx^2+(ab+ac+bc)x-r$, and replacing $x$ with $c$ gives $f(c)=c^3-mc^2+(ab+ac+bc)c-r=0$.
Now, compare the coefficients of $c^2$ and $c$ from $c^3+(6+m)c^2-k=0$ and $c^3-mc^2+(ab+ac+bc)c-r=0$ we obtain
$m=a+b+c=-3$, $ab+ac+bc=0$
From the equation $(a+b+c)^2=a^2+b^2+c^2+2(ab+bc+ca)$, we get
$a^2+b^2+c^2=9$
and $a^3+b^3+c^3=6(9)-75=-21$
Since $(a+b+c)^3=a^3+b^3+c^3+3(a^2b+b^2c+c^2a+ab^2+bc^2+ca^2)+6abc$,
we get the value of $abc$ by substituting all the values that we found into the equation above:
$(-3)^3=-21+3(a^2(b+c)+b^2(c+a)+c^2(a+b))+6abc$
$-27=-21+3(a^2(b+c+a-a)+b^2(c+a+b-b)+c^2(a+b+c-c))+6abc$
$6abc=-6-3((b+c+a)(a^2+b^2+c^2)-(a^3+b^3+c^3))$
$6abc=-6-3((-3)(9)-(-21))$
$6abc=12$
$abc=2$
FAQ: Find Product of 3 Real Numbers if System of Eqns Satisfied
What is the purpose of finding the product of 3 real numbers if a system of equations is satisfied?
The purpose of finding the product of 3 real numbers if a system of equations is satisfied is to determine the relationship between the three numbers and how they interact with each other in a given system of equations. It allows us to understand the behavior of the system and make predictions based on the product of the three numbers.
What information is needed to find the product of 3 real numbers if a system of equations is satisfied?
To find the product of 3 real numbers if a system of equations is satisfied, we need to know the values of the three numbers and the equations that they satisfy. This information allows us to plug in the values into the equations and solve for the product.
Can the product of 3 real numbers be negative if a system of equations is satisfied?
Yes, the product of 3 real numbers can be negative if a system of equations is satisfied. This depends on the values of the numbers and the equations that they satisfy. Some systems may result in a negative product, while others may result in a positive product.
Is it possible to find the product of 3 real numbers if a system of equations is not satisfied?
No, it is not possible to find the product of 3 real numbers if a system of equations is not satisfied. The purpose of finding the product is to understand the behavior and relationship between the numbers in a given system. If the system is not satisfied, there is no relationship to analyze and the product cannot be determined.
How can finding the product of 3 real numbers if a system of equations is satisfied be applied in real life?
Finding the product of 3 real numbers if a system of equations is satisfied can be applied in various fields such as physics, engineering, and economics. It can be used to model and predict the behavior of a system, analyze data and trends, and make informed decisions based on the relationship between the numbers. For example, in economics, the product of three real numbers can represent the demand, supply, and price in a market system. By analyzing the product, we can understand the dynamics of the market and make predictions for future trends.
