Find quantity of vector projection
Thinking)Yeah, you got it! Great job! (Smile)In summary, we discussed the projection of a vector onto a subspace and how to find the coordinates of the projection using the vector rejection formula. We also learned the vector projection formula and how to use it when the vectors span the subspace instead of being perpendicular to it. Finally, we solved a problem involving finding the number $2x+7y+3z$ when given a projection onto a subspace.
evinda
MHB
3,836
Hello! (Wave)
Let $W$ be the subspace of $\mathbb{R}^3$ that is orthogonal to the vector $w_1=(-1,-1,1)$ and $p=(x,y,z)$ the projection of the vector $v=(-1,1,2)$ onto $W$. What is $7x-11y+5z$ equal to?I have thought the following:
$\text{proj}_Wv=\frac{\langle v, w_1\rangle}{\langle w_1, w_1\rangle} w_1 \Rightarrow (x,y,z)=\frac{(-1,1,2) \cdot (-1,-1,1)}{(-1,-1,1) \cdot (-1,-1,1)} (-1,-1,1) =\frac{1-1+2}{1+1+1}(-1,-1,1)=\frac{2}{3}(-1,-1,1)=\left( -\frac{2}{3},-\frac{2}{3},\frac{2}{3}\right)$
Then we get that
$$7x-11y+5z=7 \left( -\frac{2}{3}\right)-11\left( -\frac{2}{3}\right)+5\left( \frac{2}{3}\right)=6$$Have I done something wrong? Because the possible answers are $-4,-12,9,15,-14,13$.
evinda said:
Hello! (Wave)
Then we get that
Hey evinda!
Your projection on $W$ is actually the projection on $W^\perp$.
Instead we should have:
$$\text{proj}_Wv=v-\text{proj}_{W^\perp}v=v - \frac{\langle v, w_1\rangle}{\langle w_1, w_1\rangle} w_1$$
(Thinking)
I like Serena said:
Hey evinda!
(Thinking)
Ah! Is it known that this formula represents the projection of $v$ onto $W$ ? (Thinking)
Using this formula, I got that $(x,y,z)=\left( -\frac{1}{3}, \frac{5}{3}, \frac{4}{3}\right)$ and thus $7x-11y+5z=-14$.
It's indeed a known formula and it's called vector rejection.
We can see why it works in this picture:
\begin{tikzpicture}[>=stealth',rotate=10]
%preamble \usetikzlibrary{arrows}
\draw[dashed] (3,0) -- (3,4);
\draw[dashed] (0,-1) -- (0,5) node
{$w_1^\perp$};
\draw[->] (0,0) -- (5,0) node[above] {$w_1$};
\draw[ultra thick,blue,->] (0,0) -- (3,4) node[above] {$v$};
\draw[->] (3,4) -- (0,4);
\draw[thick,->] (0,0) -- node
{$v-\frac{v\cdot w_1}{w_1\cdot w_1}w_1$} (0,4);
\draw[thick,->] (0,0) -- node[below] {$\frac{v\cdot w_1}{w_1\cdot w_1}w_1$} (3,0);
\end{tikzpicture}
The vector $\frac{v\cdot w_1}{w_1\cdot w_1}w_1$ is the so called vector projection.
From the picture we can see how we can construct the vector projection on the perpendicular space.
And if $w_1$ is a vector with length 1, these formulas simplify to $(v\cdot w_1)w_1$ respectively $v-(v\cdot w_1)w_1$. (Nerd)​
\begin{tikzpicture}[>=stealth']
{$w_1^\perp$};
\end{tikzpicture}
Ok, thanks a lot! (Smirk)​
With the same logic, I wanted to solve the following:
Let $W$ the subspace of $\mathbb{R}^3$ that is spanned by $w_1=(1,-1,0)$, $w_2=(1,1,2)$ and $p=(x,y,z)$ the projection of the vector $v=(-1,1,2)$ onto $W$. What is the number $2x+7y+3z$ equal to?
Using the formula, I got that
$$(x,y,z)=(-1,1,2)- \left( \frac{(-1,1,2) \cdot (1,-1,0)}{(1,-1,0) \cdot (1,-1,0)}(1,-1,0)+\frac{(-1,1,2) \cdot (1,1,2)}{(1,1,2) \cdot (1,1,2)}(1,1,2)\right)=\left( -\frac{2}{3},-\frac{2}{3}, \frac{2}{3}\right)$$
Then $2x+7y+3z=-4$. But this isn't a possible answer... (Worried)
Have I done something wrong? (Thinking)
This time round we have vectors that span $W$ instead of being perpendicular to $W$.
So we need the vector projection formula instead of the vector rejection formula.
Alternatively we can find the vector $n$ that is perpendicular to both $w_1$ and $w_2$, and then we can use the vector rejection formula. (Thinking)
Ah ok... So we have that $(x,y,z)=\frac{(-1,1,2) \cdot (1,-1,0)}{(1,-1,0) \cdot (1,-1,0)}(1,-1,0)+\frac{(-1,1,2) \cdot (1,1,2)}{(1,1,2) \cdot (1,1,2)} \cdot (1,1,2)=\left( -\frac{1}{3}, \frac{5}{3}, \frac{4}{3}\right)$ and thus $2x+7y+3z=15$, right? (Thinking)
Yep. (Nod)
I like Serena said:
Yep. (Nod)
Nice... thank you (Smirk)
