MHB Find radius, circumference, area and arc length in circle
The discussion focuses on calculating various properties of a circle, including radius, circumference, area, and arc length. The user successfully determined the radius as 12 inches, circumference as 75.3982 inches, and area as 452.389 square inches. However, they are struggling with the arc length calculation. A participant suggests using the formula for arc length, which involves taking a fraction of the circumference based on the angle in degrees. The conversation emphasizes the importance of expressing answers in terms of π.
Etrujillo
So I've been able to solve
A.12 inch
B.24 inch
C.75.3982
D.452.389
Cant solve e. Arc length can anyone please explain the formula. Thank you
Mathematics news on Phys.org
A.12 inch
B.24 inch
C.75.3982
D.452.389
So far so good.
You know that the circumference is 75.3982 in, then how much is 105/360 of it?
-Dan
Note that the instructions say to express your answers in terms of \(\pi\). :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
