Albert1
- 1,221
[sp]I used trigonometry. If $\theta$ is the angle $BAC$, then $\sin\theta = 3/5$. If $t = \tan(\theta/2)$ then one of the half-angle formulas says that $\sin\theta = \dfrac{2t}{1+t^2} = \dfrac35$, from which $3t^2-10t+3=0.$ The solutions to that are $t=1/3$ and $t=3$. Clearly $t=3$ is too big, and so $\tan(\theta/2) = 1/3.$ But the line $AO_1$ bisects angle $BAC$, and therefore $O_1Q/AQ = 1/3$. So $AQ=3s$. Since $QC = O_1R = 3s$, it follows that $12 = AC = 6s$, and so $s=2$.[/sp]Albert said:
[sp]I believe that the dashed lines in the diagram give a clue. They divide the triangle ABC into three smaller triangles, whose areas are $\frac12(12s)$, $\frac12(9(3s))$ and $\frac12(15s)$ (using Pythagoras to get the hypotenuse of triangle ABC as 15). The area of the whole triangle is $\frac12(9\times12)$. Equating that to the sum of the three smaller areas easily gives the equation $27s=54$ from which $s=2$.[/sp]Albert said:I will use geometry ,
maybe someone want to try it first
yes ,you got it:)Opalg said:[sp]I believe that the dashed lines in the diagram give a clue. They divide the triangle ABC into three smaller triangles, whose areas are $\frac12(12s)$, $\frac12(9(3s))$ and $\frac12(15s)$ (using Pythagoras to get the hypotenuse of triangle ABC as 15). The area of the whole triangle is $\frac12(9\times12)$. Equating that to the sum of the three smaller areas easily gives the equation $27s=54$ from which $s=2$.[/sp]
The formula for finding the radius of a circle is r = d/2, where r is the radius and d is the diameter of the circle.
To calculate the radius of a circle if you only know the circumference, you can use the formula r = C/(2π), where r is the radius and C is the circumference.
Yes, you can find the radius of a circle if you only know the area. The formula for this is r = √(A/π), where r is the radius and A is the area of the circle.
The units used for the radius of a circle will depend on the units used for the other measurements. For example, if the diameter is measured in meters, the radius will also be in meters. It is important to keep the units consistent throughout the calculation.
Yes, you can use a calculator to find the radius of a circle. Most scientific or graphing calculators have a built-in function for calculating the radius of a circle using the known measurements such as diameter, circumference, or area.
