Find Real Root: $x^5-10x^3+20x-12=0$
  • MHB
  • Thread starter anemone
  • Tags
    Root
In summary, a real root of the equation $x^5-10x^3+20x-12=0$ can be found by using the substitution $x = t + \dfrac at$ and solving for $t$, which leads to the solution $x= 2^{2/5} + 2^{3/5}$. This method is based on the quadratic formula and does not require the use of a computer.
anemone
MHB
POTW Director
3,883
115
Find a real root of $x^5-10x^3+20x-12=0$.
Mathematics news on Phys.org
let: $f(x)=x^5-10x^3+20x-12=0---(1)$
then
$f'(x)=5x^4-30x^2+20$
we know if $x\geq 3$ then (1) no solution
$f(2.83)<0,f(3)>0$
there is a soluion $2.83<x<3$
using Newton's Method:
$x=r - \dfrac{f(r)}{f'(r)}$
if $r=2.83$
we get one solution $x\approx 2.835263$
then
$f(2.83)<0,f(3)>0$
if $r=2.83$
Thanks for participating, Albert! Yes, that is right! Well done!
But what if we want to find the exact root?(Happy)
I considered posting the result from Newton's method, but something told me you want the exact value...:D
Aww...I must apologize for not being very clear in the problem ...sorry!(Tmi):eek:
It's a DeMoivre quintic. The real root is $$8^{1/5}+\frac{2}{8^{1/5}}$$
we can never get the exact value of :
$\pi,e,\sqrt 2,\sqrt [5] 8---$ right ?
It is true that we can never write the exact value of irrational numbers in decimal form, but giving their symbol or radical notation represents their exact values. :D
anemone said:
Find a real root of $x^5-10x^3+20x-12=0---(1)$.
there is only one real solution k for (1)
if all the solutions of (1) are:
$a\pm bi$,$c\pm di$ and k(real) then :
linear equations:
$2a+2c+k=0-----(1)$
$(a^2+b^2)(c^2+d^2)k=12---(5)$
we will have 5 equations and 5 valuables .it is too complicated ,and should be solved by computer
Actually, general solutions to several types of quintic equations were found decades before computers were invented.
Thank you MarkFL, greg1313 and Albert for all of the responses...
Solution of other:
Use the substitution where $x=2\sqrt{2}\cosh y$, we see that
$x^5-10x^3+20x-12=0$ becomes
$(2\sqrt{2}\cosh y)^5-10(2\sqrt{2}\cosh y)^3+20(2\sqrt{2}\cosh y)-12=0$
$128\sqrt{2}(\cosh y)^5-160\sqrt{2}(\cosh y)^3+40\sqrt{2}(\cosh y)-12=0$
$\dfrac{128\sqrt{2}(\cosh y)^5}{8\sqrt{2}}-\dfrac{160\sqrt{2}(\cosh y)^3}{8\sqrt{2}}+\dfrac{40\sqrt{2}(\cosh y)}{8\sqrt{2}}=\dfrac{12}{8\sqrt{2}}$
$16\cosh^5 y-20\cosh^3 y+5\cosh y=\dfrac{3}{2\sqrt{2}}$
Using the multiple angle formula for hyperbolic $\cosh$ function we get
$(10\cosh y+5\cosh 3y+\cosh 5y)-(15\cosh y+5\cosh 3y)+5\cosh y=\dfrac{3}{2\sqrt{2}}$
$5\cosh 3y=\dfrac{3}{2\sqrt{2}}$
According to the definition $\cosh^{-1} a=\ln (a\pm\sqrt{a^2-1})$, we find $5y=\ln \left(\dfrac{3\sqrt{2}}{4}\pm\dfrac{\sqrt{2}}{4}\right)=\pm\dfrac{\ln 2}{2}\implies y=\pm 0.1\ln 2$
Again, by the definition $\cosh a=\dfrac{e^{a}+e^{-a}}{2}$, we have
$\begin{align*}x&=2\sqrt{2}\cosh y\\&=2\sqrt{2}\left(\dfrac{e^{0.1\ln 2}+e^{-0.1\ln 2}}{2}\right)\\&=\sqrt{2}(2^{0.1}+2^{-0.1})\\&=2^{0.6}+2^{0.4}\end{align*}$
This is just to explain how the hint given by greg1313 in comment #6 leads to the solution given by anemone.
[sp]
We look for a solution of the form $x = t + \dfrac at$. Then
$x^5 = t^5 + 5at^3 + 10 a^2t + 10a^3t^{-1} + 5a^4t^{-3} + a^5t^{-5}.$
Also, $x^3 = t^3 + 3at + 3a^2t^{-1} + a^3t^{-3}.$
Therefore $x^5 - 5ax^3 = t^5 - 5a^2t - 5a^3t^{-1} + a^5t^{-5},$ and $x^5 - 5ax^3 + 5a^2x = t^5 + a^5t^{-5}.$
Comparing that with the given equation $x^5-10x^3+20x-12=0$, you see that if we take $a=2$ then we get $x^5-10x^3+20x = t^5 + 32t^{-5}.$
So we want $t^5 + 32t^{-5} = 12$, or $t^{10} - 12 t^5 + 32 = 0.$ That is a quadratic in $t^5$, with solutions $t^5 = 4$ or $8$. Thus $t = 2^{2/5}$ or $2^{3/5}$. Substitute either of those values into the equation $x = t + \dfrac 2t$ and you get the solution $x= 2^{2/5} + 2^{3/5}$ (which is also the solution stated by greg1313).[/sp]
FAQ: Find Real Root: $x^5-10x^3+20x-12=0$
What is a real root?
A real root is a value of x that makes the equation true when substituted into the equation. In other words, it is the value that satisfies the equation and makes it equal to 0.
How do you find the real roots of a polynomial equation?
To find the real roots of a polynomial equation, you can use a variety of methods such as factoring, the rational root theorem, or the quadratic formula. In this specific equation, we can use the rational root theorem to narrow down the possible values of x and then use synthetic division or long division to find the roots.
Can a polynomial equation have more than one real root?
Yes, a polynomial equation can have multiple real roots. In this case, the given equation is a fifth-degree polynomial, which means it can have up to five real roots. However, it is also possible for a polynomial equation to have less than the maximum number of real roots or even no real roots at all.
What is the importance of finding the real roots of a polynomial equation?
Finding the real roots of a polynomial equation can help us solve real-world problems and make predictions. It can also help us understand the behavior of the equation and make connections to other mathematical concepts, such as the graph of the equation.
Is there a specific method to find the real roots of a fifth-degree polynomial equation?
There is no specific method to find the real roots of a fifth-degree polynomial equation, but there are several techniques and formulas that can be used. Some commonly used methods include the rational root theorem, the Descartes' rule of signs, and the intermediate value theorem. Ultimately, the most appropriate method will depend on the specific equation and its characteristics.
