Find Real Solutions: Solving $\sqrt{4a-b^2}=\sqrt{b+2}+\sqrt{4a^2+b}$
  • MHB
  • Thread starter anemone
In summary, the first step in solving this equation is to isolate the square root terms on one side of the equation. This equation can have more than one solution, as the square root terms can simplify to the same or different values. There are restrictions on the variables, as the expressions under the square root must be greater than or equal to 0. This equation can be solved algebraically, potentially involving the quadratic formula. It is also possible to graph this equation, with the graph representing all the points that satisfy the equation.
anemone
MHB
POTW Director
3,883
115
Find the real solution(s) to the system
Mathematics news on Phys.org
My solution:
Squaring and rearranging terms yields:\[4a-b^2 = b+2+4a^2+b + 2\sqrt{(b+2)(4a^2+b)}\\\\ -(b^2+2b+1)-4(a^2-a+\frac{1}{4}) = 2\sqrt{(b+2)(4a^2+b)}\]
- under the conditions:
$4a-b^2 \geq 0 \wedge b \geq -2$ or $a \geq \left ( \frac{b}{2} \right )^2 \wedge b \geq -2$.The LHS $\le 0$:
\[-(b+1)^2-4(a-\frac{1}{2})^2=-\left ( (b+1)^2+4(a-\frac{1}{2})^2 \right ) \le 0\]The RHS $\ge 0$, so the only possibility is: $b = -1$ and $a = \frac{1}{2}$. Checking the RHS: $4a^2+b = 0$. OK.
lfdahl said:
My solution:
Very well done, lfdahl and thanks for participating!(Cool)
FAQ: Find Real Solutions: Solving $\sqrt{4a-b^2}=\sqrt{b+2}+\sqrt{4a^2+b}$
What is the first step in solving this equation?
The first step in solving this equation is to isolate the square root terms on one side of the equation.
Can this equation have more than one solution?
Yes, this equation can have more than one solution. It is possible for the square root terms to simplify to the same value, resulting in only one solution. But it is also possible for the square root terms to simplify to different values, resulting in two solutions.
Are there any restrictions on the variables in this equation?
Yes, there are restrictions on the variables in this equation. The value inside the square root cannot be negative, so the expressions under the square root must be greater than or equal to 0. This means that there are certain combinations of values for a and b that will not be valid solutions.
Can this equation be solved algebraically?
Yes, this equation can be solved algebraically. It may involve simplifying the square root terms, using properties of exponents, and possibly using the quadratic formula to solve for the variable.
Is it possible to graph this equation?
Yes, it is possible to graph this equation. The graph would be a curve representing all the points that satisfy the equation. It may be helpful to graph each side of the equation separately and find the points of intersection to determine the solutions.
