MHB Find Recurrence Relation for Flipping n Switches
The discussion focuses on finding a recurrence relation for flipping n switches, where the nth switch can only be flipped if the (n-1)th switch is on and all earlier switches are off. The proposed relation is f_n = f_{n-1} + 2, with the initial condition f_1 = 1, which is justified by the need to turn on the nth switch and then turn off the (n-1)th switch. Participants also explore the advantages of using recurrence relations over regular equations, noting that they can simplify definitions and are often more intuitive for certain problems. Recursion is highlighted as a powerful tool in algorithm design, particularly in divide-and-conquer strategies. Overall, the conversation emphasizes the utility of recurrence relations in mathematical problem-solving.
find_the_fun
A circuit has n switches, all initially off. In order to be able to flip the ith switch, the (i-1)th switch must be on and all earlier switches off. The first switch can always be flipped. Find a recurrence relation for the total number of times the n switches must be flipped to get the nth switch on and all the others off.
I got [math]f_n=f_{n-1}+2[/math] with initial condition [math]f_1=1[/math] Is this right? This makes sense because to get the nth switch on, you need the (n-1)th switch on, and then you need to turn on the nth switch itself and turn off the (n-1)th switch. I have trouble explaining this using math though.
Re: Finding a recurrence relation where (k-1)th switch must be on to turn on kth switch
You can't turn off the $(n-1)$th switch by flipping it alone.
Speaking in general, what's the point of recurrence relations? Why not use a regular equation? Is it because in some situations it may be easier to derive/discover a recurrence relation?
Yes. Recurrence relation is itself a function defined by recursion, i.e., the definition of such function refers to the function itself. And recurrence relation naturally accompany definitions by recursion, which may not even involve numbers (structural recursion). For example, it is easy to describe a recursive algorithm for solving Hanoi towers puzzle; a corresponding recurrence relation may count the required number of moves.
So, why is recursion useful?
(1) Recursive definitions are often simpler. For example, it is easy to come up with the recurrence relation for Fibonacci numbers from the description of the rabbit population growth, as in the original puzzle. Deriving Binet's formula is harder.
(2) Certain constructions of objects (numbers, lists, etc.) naturally lead to recursive definitions. Such constructions define how to build an object from existing ones: e.g., a list is either empty or a pair of a number and a list. Functions that take lists as arguments are often defined by recursion.
(3) The "divide-and-conquer" and dynamic programming techniques of building algorithms (e.g., binary search) use recursion to increase efficiency.
(4) Functions defined by recursion often can't be expressed using only operations from the definition. For example, the definition of factorial uses only 1 and multiplication, but the factorial is different from the four arithmetic operations. Concerning hailstone numbers, nobody knows if every starting number eventually turns into 1.
Remark: Some people make distinction between recurrence and recursion: the former is a special case of the latter. Since natural numbers can be considered built from 0 by using successor, a definition that gives f(n+1) from f(n) is a definition by recurrence, while the one that produces f(n) from f(n/2) uses more general recursion.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
