MHB Find relation equation between a,b
  • Thread starter Thread starter Albert1
    Relation
The discussion focuses on finding a relationship between the constants a and b in the equations y = x^3 - ax^2 - bx and y = ax + b, where x is a negative integer and y is a positive integer. Participants explore how to derive this relationship and identify pairs of (x, y) that satisfy both equations. The conversation also touches on the co-primality of x^3 and 1+x, with references to Euclid's algorithm for clarification. The primary goal is to establish the conditions under which the equations hold true for the specified integer constraints. Understanding these relationships is crucial for solving the equations effectively.
Albert1
$y=x^3-ax^2-bx---(1)$
$y=ax+b---(2)$
$a,b\in R$
$x$ is a negative integer, $y$ positive integer
(1) find the relative equation between $a$ and $b$
(2)pair(s) of $(x,y)$
Mathematics news on Phys.org
$y=ax+b---(2)$
$a,b\in R$
we have $y=x^3- ax^2-bx = x^3 - x(ax+b) = x^3-xy$ using (2)
or $y+xy = x^3$
or $y = \frac{x^3}{1+x}$
now $x^3$ and (1+x) are co-primes and 1 + x is not a factor of $x^3$ unless $1+x = \pm 1$
and $1+x=1$ gives x = 0 which is not admissible
so $1+x = -1$ hence $x = -2 $ and $y=8$ so this is the solution as it satisfied x -ve and y + ve
putting in (2) we get
8 = -2a + b or $2a-b = -8$ is the relationship between a and b
or $y+xy = x^3$
8 = -2a + b or $2a-b = 8$ is the relationship between a and b
How do you know $x^3$ and $1+x$ are co-prime?
because $x^3+1 = (x+1)(x^2-x + 1)$
so $x^3 = (x+1)(x^2-x+1) + 1$
so $GCD(x^3, x + 1) = GCD(- 1,x +1) =1$ or -1 if you like it and hence co-primes unless $x +1 = \pm 1$
Euclid's algorithm; ok thanks
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
