MHB Find Remainder When Divided by 19
  • Thread starter Thread starter Deanmark
    Remainder
To find the remainder of 2^(2^17) + 1 when divided by 19, it is necessary to first compute 2^17 mod 18 due to Fermat's Little Theorem, which states that a^(p-1) mod p equals 1 for a prime p. By expressing 2^17 as a multiple of 18 plus a remainder, the calculation simplifies to 2^(18k + r) mod 19, which can be reduced to 2^r + 1 mod 19. This approach allows for easier computation of the original expression. Understanding this method clarifies the reasoning behind using mod 18 before applying mod 19.
Deanmark
Compute the remainder of 2^(2^17) + 1 when divided by 19. The book says to first compute 2^17 mod 18 but I don’t understand why we go to mod 18. Advice would be appreciated
Mathematics news on Phys.org
Hi Deanmark,
That's because of the Little Theorem of Fermat:
$$a^{p-1} \bmod p = 1$$
where $p$ is prime and $a$ is any number except for a multiple of $p$.
So if we can write $2^{17}$ as some multiple of $18$ and a remainder, say $2^{17} = 18k + r$, then:
$$2^{(2^{17})} + 1 \bmod 19 = 2^{18k+r} + 1 \bmod 19 = (2^{18})^k\cdot 2^r + 1 \bmod 19 = 2^r + 1 \bmod 19$$
The parts of my wall that have yet to be punched thank you.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
