MHB Find Rhombus Angles: 360º & 22º30
  • Thread starter Thread starter Joostrea
    Angles
The angle between the diagonal and the side of the rhombus is 22º30’. The interior angles of a rhombus total 360º, with opposing angles being congruent. The calculations show that angle B is 45º, derived from doubling 22º30’. Consequently, angles C and E are both 135º, confirming the angle relationships in the rhombus. The calculations are correct, validating the findings.
Joostrea
The angle between the diagonal and the side of the rhombus is 22º30’. Find rhombus angles.
Rhombus interior angles are 360º that much I know, but how do I find out the other angles?
Mathematics news on Phys.org
Just remember that by definition, a rhombus is always going to be congruent on opposing sides of each diagonal. See if this helps you get started...
B=22º30’*2=45º
B=45º
D=45º
45º+C=180º
C=135º
E=135º
Did I do it right?
Joostrea said:
B=22º30’*2=45º
B=45º
D=45º
45º+C=180º
C=135º
E=135º
Did I do it right?
Yup. Good job : )
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
