Find roots of the EQN: r^3-r^2+1=0
  • Thread starter fridakahlo
  • Tags
    Roots
In summary: The point is that this problem is similar to other problems that can be solved in a textbook, but there may be easier methods that the OP can try if they do not want to try the textbook methods.
fridakahlo
none
r^2(r-1)+1=0
from there i solved, r^2=-1 and r-1=-1 to find the following roots:
r=+i,r=-i, r=0
Is my method correct? Also, I don't think that synthetic division would work here since my possible rational zeroes are +1/-1, and those don't satisfy the equation when they are plugged in for 'r'.
If you plug your solutions into the polynomial do you get 0?
none
r^2(r-1)+1=0
r=+i,r=-i, r=0
No, this is not correct. If a * b = 0, then you know that either a or b must be zero, but if a * b = 1, then there are an infinite number of possible solutions for a and b.
Even though you haven't found the roots of the equation, you learned from doing synthetic division that if r = 1, r^3 - r^2 + 1 > 0 and if r = -1, then r^3 - r^2 + 1 < 0. That implies that there must be a root of the equation somewhere between -1 and +1.
Likes scottdave
We can always solve this equation algebraically by a general method for solving cubics. However the question seems to be, can we without that find an easier method to see solutions depending on the apparent special simplifying features of this equation?
How does the problem arise? If it is an excercise from a book, what is the chapter and maybe section about? Are there any similar problems solved? Same if a course of lessons.
I tried a few plausible approaches but got nothing. At this point I recall we here have often been able to solve seemingly intractable problems after asking the poster to check whether he had copied it out right. :oldbiggrin:
If synthetic division does not give you remainder of 0, then the three possible roots would be irrational(?), not sure if all Real. I would turn to graphing software to check.
(Google shows a graph of the function having just one real root. Near -0.76)
By hand it's fairly easy to see that this function has a maximum at x = 0, and a minimum at positive x and f so can have only one real root which must be negative.
We now need the OP's confirmation and explanation of the origin of this problem.
These extrema would be local maximum and local minimum.
I agree we should wait for the OP to weigh in again.
:doh: Somebody who apparently doesn't want to be identified reminded of what I had forgotten trying to do algebra on this, looks like this was an exercise in the trigonometrical solution.
How ?
Buffu said:
How ?
Well as the OP has not come back I feel a sufficient answer is in the unanswered #4
There is something about cos3 x and cubics in all the textbooks.
r=-i or r=+i,,,,,r=0
There is a way to solve cubic equations (which I wrote an Insights article about). Skipping to the punch line...
If you have the cubic equation [itex]r^3 + A r^2 + B r + C = 0[/itex], then find three numbers [itex]a, b, c[/itex] such that:
  1. [itex]a = -A/3[/itex]
  2. [itex]3a^2 - 3bc = B[/itex]
  3. [itex]a^3 + b^3 + c^3 - 3abc = -C[/itex]
Then one solution is [itex]r_1 = a + b + c[/itex]. How do you find those three numbers? Well, the first equation gives you [itex]a[/itex]. Then the second equation gives you [itex]c = \frac{a^2 - B/3}{b}[/itex]. Plugging that into the third equation gives:
[itex]a^3 + b^3 + \frac{(a^2 - B/3)^3}{b^3} - 3a (a^2 - B/3) + C = 0[/itex]
That seems like a mess, but it becomes simpler if you multiply through by [itex]b^3[/itex] it becomes:
[itex]b^6 + (a^3 - 3a (a^2 - B/3) + C) b^3 + (a^2 - B/3)^3 = 0[/itex]
Then you subtitute [itex]z = b^3[/itex], and it becomes a quadratic equation for [itex]z[/itex]. Solve for [itex]z[/itex], then get [itex]b[/itex] and then get [itex]c[/itex].
My calculations gave a solution of [itex]a = 0.333, b = -0.114, c = -0.974[/itex], which gives a solution [itex]r_1 = -.755[/itex] (to 3 digits).
What is the point in copying what already written.
stevendaryl said:
My calculations gave a solution of a=0.333,b=−0.114,c=−0.974a=0.333,b=−0.114,c=−0.974a = 0.333, b = -0.114, c = -0.974, which gives a solution r1=−.755r1=−.755r_1 = -.755 (to 3 digits).
But those are just approximations.
Well, I sketched how to get an exact answer. What more do you want?
Letting [itex]K = (\frac{25 - \sqrt{621}}{54})^{\frac{1}{3}}[/itex], one solution is:
[itex]r_1 = \frac{1}{3} - \frac{1}{9K} - K[/itex]
Referring to stevendaryl's solution:0.755
I believe the 3, I might be convinced the solution has a 9, but are you sure the cubic equation solution really has a square root of what, (a 621). A cube root of
(25 - square root divided by 54) ?
The cubic equation is so simple r cube - r squared + 1 = 0.
PS. I used MATLAB and your solution works! I can't believe it. There must be another universe somewhere where the solution to this equation is simpler.
0.755 is about pi /4. Are you sure the answer isn't really just pi / 4, and we are in the wrong universe.
Related to Find roots of the EQN: r^3-r^2+1=0
What is the equation we are trying to find the roots of?
The equation we are trying to find the roots of is r^3-r^2+1=0.
What is the definition of a root?
A root is a value that, when substituted into the equation, makes the equation equal to 0.
How many roots can an equation have?
The number of roots an equation can have is equal to its degree. Since this equation is of degree 3, it can have up to 3 roots.
How can we find the roots of this equation?
To find the roots of this equation, we can use various methods such as factoring, the quadratic formula, or the cubic formula.
What are the possible solutions for this equation?
Based on the coefficients of this equation, the possible solutions are real or complex numbers. However, since this equation has a degree of 3, it may have up to 3 real or complex solutions.
