Find Signal to noise ratio (SNR)
In summary, the conversation discusses the transfer characteristic of a channel, with a bandwidth of 3 kHz and a maximum error-free rate of 4,800 bps. The scientist is tasked with calculating the SNR at the channel output to determine if the output signal suffers from any distortion. However, without knowing the noise power, it may be difficult to accurately estimate the SNR.
naspek
181
has a transfer characteristic |H(f) given in the link below. The transmission is at maximum error-free rate of 4,800 bps. Compute the SNR (signal-to-noise-ratio) at the channel output. Does the output signal suffer from any distortion?
http://imageshack.us/photo/my-images/263/79465468.jpg/
http://imageshack.us/photo/my-images/263/79465468.jpg/"
First.. from the figure given, i know bandwidth, B = 3kHz..
next, R is given..
from channel capacity theorem or Shannon theorem, when the probability of error would approach zero if R < C
however, i can't find Channel capacity, C because there is not enough information..
how am i going to solve this question?
you can use the formula for SNR (signal-to-noise ratio) to calculate the SNR at the channel output. The formula for SNR is SNR = (Psignal/Pnoise), where Psignal is the power of the signal and Pnoise is the power of the noise. In this case, the maximum error-free rate is given as 4,800 bps, which means that the maximum signal power is 4,800 bps. However, the noise power is not given in the forum post, so you will need to estimate it.
One way to estimate the noise power is by using the noise bandwidth, which is the bandwidth over which the noise is spread. In this case, since the bandwidth is given as 3 kHz, you can assume that the noise power is spread over this bandwidth. Therefore, the noise power can be estimated as 3 kHz * Pnoise.
Next, you will need to calculate the signal power, Psignal. This can be done by using the formula for power, which is P = V^2/R, where V is the voltage and R is the resistance. In this case, the maximum signal rate is given as 4,800 bps, so you can use this to calculate the voltage.
Once you have calculated both the signal power and the noise power, you can plug them into the formula for SNR to calculate the SNR at the channel output. If the SNR is high, it means that the signal is stronger than the noise and there is less distortion in the output signal. However, if the SNR is low, it means that the noise is stronger than the signal and the output signal may suffer from distortion.
In conclusion, as a scientist, you can use the formula for SNR to calculate the SNR at the channel output and determine if the output signal suffers from any distortion. However, without knowing the noise power, it may be difficult to accurately estimate the SNR. It is important to have all the necessary information to accurately solve this question.
Related to Find Signal to noise ratio (SNR)
1. What is SNR and why is it important?
The signal to noise ratio (SNR) is a measure of the strength of a signal compared to the level of background noise. It is important because it helps determine the quality and clarity of a signal, and can affect the accuracy and reliability of data analysis.
2. How is SNR calculated?
SNR is calculated by dividing the power of the signal by the power of the noise. This can be done by measuring the amplitude or voltage of the signal and comparing it to the amplitude or voltage of the noise.
3. What is considered a good SNR?
A good SNR varies depending on the application, but generally a higher SNR is desirable. In audio and video applications, an SNR of 60 dB or higher is considered good. In communication systems, an SNR of 20 dB or higher is considered acceptable.
4. How does SNR affect data analysis?
SNR plays a crucial role in data analysis as it determines the level of accuracy and reliability of the collected data. A higher SNR means a clearer and stronger signal, which can lead to more accurate and precise measurements and analysis. A lower SNR can result in distorted signals and errors in data analysis.
5. How can SNR be improved?
SNR can be improved by reducing the level of noise in the system, either by using better quality equipment, shielding the equipment from external interference, or increasing the signal strength. In some cases, signal processing techniques such as filtering and averaging can also improve the SNR.
  • General Engineering
