Find Speed in Centripetal Motion
In summary, at the top of the loop in a loop-to-loop roller coaster with a radius of curvature of 12 m, the force exerted by the seat on a passenger of mass m is 0.4mg, providing the centripetal force. Using the equation F = ma, the speed of the roller coaster at the top of the loop can be found to be v = 12.83 m/s.
petern
89
The radius of curvature of a loop-to-loop roller coaster is 12 m. At the top of the loop, the force that the seat exerts on a passenger of mass m is 0.4mg. Find the speed of the roller coaster at the top of the loop. Answer: v = 12.83 m/s.
I assume .4 mg is the torque, right? I have no clue what to do. Please help.
At the top of the loop...what forces provide the centripetal force? the weight and the force that the seat exerts...and so...you can find v...
What do I do with the mg?
Well mg is just the formula to find weight...so that the force exerted by the seat is 0.4*(the weight of the seat)
so that weight of seat+Force exerted by seat, provides the centripetal force
So I would use the equation F = ma and a = v^2/r. I wouldn't use v = (2*pi*r)/(T) because T = period and that info is not provided. But I still don't understand what I'm suppose to do with the m and .4mg.
ok..seems you aren't getting this...
Eq'n: Centripetal Force,[itex]F_c=\frac{mv^2}{r}[/itex]
The weight of the seat(mg) + The force that the seat exerts on a passenger(0.4mg) provides the centripetal force.
This means that
[tex]F_c=mg+.4mg[/tex]
since [itex]F_c=\frac{mv^2}{r}[/itex]
then
[tex]\frac{mv^2}{r}=mg+.04mg[/tex]
What cancels out...and you have the value of 'r' and 'g'
Solved! Thank you sooo much.
FAQ: Find Speed in Centripetal Motion
What is centripetal motion?
Centripetal motion is a type of motion in which an object moves in a circular path around a fixed point. This type of motion is caused by a centripetal force, which is always directed towards the center of the circular path.
How is speed calculated in centripetal motion?
The speed in centripetal motion is calculated using the formula v = 2πr/T, where v is the speed, r is the radius of the circular path, and T is the time taken to complete one revolution. This formula is derived from the equation for centripetal acceleration, a = v^2/r, where a is the centripetal acceleration.
Can the speed in centripetal motion be constant?
Yes, the speed in centripetal motion can be constant as long as the radius of the circular path and the centripetal force remain constant. This means that the object is moving at a constant speed around the circle, but its velocity is constantly changing as it changes direction.
How does the mass of an object affect its speed in centripetal motion?
The mass of an object does not affect its speed in centripetal motion. The speed is only dependent on the radius of the circular path and the centripetal force. However, a larger mass will require a stronger centripetal force to maintain the same speed, as seen in the equation a = v^2/r.
Can you find the speed in centripetal motion without knowing the radius?
No, the speed in centripetal motion cannot be calculated without knowing the radius of the circular path. This is because the speed is directly proportional to the radius, as seen in the formula v = 2πr/T. If the radius is unknown, the speed cannot be accurately determined.
