MHB Find Stationary Points of f(x,y) Under Constraint x^3+y^3+6xy=8
  • Thread starter Thread starter Petrus
    Points
The discussion focuses on finding stationary points of the function f(x,y) = x^3y^3 under the constraint x^3 + y^3 + 6xy = 8. The use of Lagrange multipliers is suggested to solve the problem, leading to a system of equations that helps identify critical points. It is clarified that the points (0,0) and (2,-2) are not considered stationary points since the gradient of the constraint being zero is not relevant in this context. The solution confirms that the critical points obtained through the Lagrange method align with the initial findings. The conclusion emphasizes that the gradient of the constraint should not be zero for stationary point analysis in this scenario.
Petrus
Hello MHB,This is an old exam I got a question,
Decide all stationary points to function $$f(x,y)=x^3y^3$$ under constraint $$x^3+y^3+6xy=8$$So basicly this is how they Solved it and I did so as well but I Also have learned that there is stationary point where gardient of constraint is equal to zero
I am aware that you guys Dont understand but it's nr 3 and are those the stationary points or they forgot when gradient of constraint is equal to zero which gives Also this point $$(0,0)$$ and $$(2,-2)$$
Edit:svar means answer so are those point correct or?
Regards,
$$|\pi\rangle$$
I would use Lagrange multipliers for this problem.
The objective function is:
$$f(x,y)=x^3y^3$$
subject to the constraint:
$$g(x,y)=x^3+y^3+6xy-8=0$$
So, we obtain the system:
$$3x^2y^3=\lambda\left(3x^2+6y \right)$$
$$3x^3y^2=\lambda\left(3y^2+6x \right)$$
Solving both for $\lambda$ and equating, we find:
$$\lambda=\frac{x^2y^3}{x^2+2y}=\frac{x^3y^2}{y^2+2x}$$
$$x^2y^3\left(y^2+2x \right)=x^3y^2\left(x^2+2y \right)$$
$$x^2y^2\left(y\left(y^2+2x \right)-x\left(x^2+2y \right) \right)=0$$
$$x^2y^2\left(y^3+2xy-x^3-2xy \right)=0$$
$$x^2y^2\left(y^3-x^3 \right)=0$$
This leads to the same critical points as the solution you have. You don't consider where the gradient of the constraint is zero in such problems.
  • · Replies 32 ·
52K
