Find Sum of $\dfrac{4k}{4k^4+1}$
  • MHB
  • Thread starter anemone
  • Tags
    Sum
In summary, the general formula for finding the sum of the series $\dfrac{4k}{4k^4+1}$ is $\dfrac{1}{2}\ln{\left(\dfrac{k^4+1}{k^4}\right)}$. This formula can be expressed in a closed form using the natural logarithm function and can be proved using the technique of partial fractions and telescoping series. It can also be extended to other series with a similar form, and can be applied in various real-world situations such as in the fields of science, mathematics, and engineering.
anemone
MHB
POTW Director
3,883
115
Determine the sum \(\displaystyle \sum_{k=1}^n \dfrac{4k}{4k^4+1}\).
Mathematics news on Phys.org
Here is my solution:
We are given to evaluate:
\(\displaystyle S_n=\sum_{k=1}^n\left(\frac{4k}{4k^4+1} \right)\)
Partial fraction decomposition on the summand allows us to write:
\(\displaystyle S_n=\sum_{k=1}^n\left(\frac{1}{2k^2-2k+1}-\frac{1}{2k^2+2k+1} \right)\)
Observing that:
\(\displaystyle 2(k+1)^2-2(k+1)+1=2k^2+2k+1\)
and using the rule of linearity of the summand and re-indexing the first sum, we obtain:
\(\displaystyle S_n=\sum_{k=0}^{n-1}\left(\frac{1}{2k^2+2k+1} \right)-\sum_{k=1}^n\left(\frac{1}{2k^2+2k+1} \right)\)
Pulling the first term from the first sum and the last term from the second sum, we may write:
\(\displaystyle S_n=1+\sum_{k=1}^{n-1}\left(\frac{1}{2k^2+2k+1} \right)-\sum_{k=1}^{n-1}\left(\frac{1}{2k^2+2k+1} \right)-\frac{1}{2n^2+2n+1}\)
The two sums add to zero, and we are left with:
\(\displaystyle S_n=1-\frac{1}{2n^2+2n+1}=\frac{2n(n+1)}{2n^2+2n+1}\)
Observing that:
Awesome, MarkFL! (Nerd)And thanks for participating!(Sun)
Hey MarkFL, I think I should post the solution which I saw online as well, just to be fair...:eek:
\(\displaystyle \begin{align*}\sum_{k=1}^n \dfrac{4k}{4k^4+1}&=\sum_{k=1}^n \dfrac{(2k^2+2k+1)-(2k^2-2k+1)}{(2k^2+2k+1)(2k^2-2k+1)}\\&=\sum_{k=1}^n \left(\dfrac{1}{2k^2-2k+1} -\dfrac{1}{2(k+1)^2-2(k+1)+1} \right)\\&=1-\dfrac{1}{2n^2+2n+1}\end{align*}\)
and we're done.
I would approach this problem by first simplifying the expression to make it easier to work with. We can rewrite the fraction as $\frac{4k}{4k^4+1} = \frac{4k}{(2k^2)^2+1}$. This allows us to see that the denominator is in the form of a perfect square plus 1, which can be factored using the difference of squares formula.
So, we can rewrite the fraction as $\frac{4k}{(2k^2)^2+1} = \frac{4k}{(2k^2+1)(2k^2-1)}$. Now, we can use partial fraction decomposition to write this as $\frac{A}{2k^2+1} + \frac{B}{2k^2-1}$.
Solving for A and B, we get $A = 1$ and $B = -1$. Therefore, we can rewrite the original expression as $\frac{4k}{4k^4+1} = \frac{1}{2k^2+1} - \frac{1}{2k^2-1}$.
Now, we can use the summation property $\sum_{k=1}^n (a_k + b_k) = \sum_{k=1}^n a_k + \sum_{k=1}^n b_k$ to split the summation into two separate summations. This gives us $\sum_{k=1}^n \frac{4k}{4k^4+1} = \sum_{k=1}^n \frac{1}{2k^2+1} - \sum_{k=1}^n \frac{1}{2k^2-1}$.
Now, we can use the summation formula for geometric series $\sum_{k=1}^n ar^{k-1} = \frac{a(1-r^n)}{1-r}$ to evaluate each summation separately. Plugging in $a = 1$, $r = \frac{1}{2}$, and $n = \infty$, we get $\sum_{k=1}^n \frac{1}{2k^2+1} = \frac{1}{2}\left(1 - \frac{1}{2^n}\right
FAQ: Find Sum of $\dfrac{4k}{4k^4+1}$
What is the general formula for finding the sum of the series $\dfrac{4k}{4k^4+1}$?
The general formula for finding the sum of the series $\dfrac{4k}{4k^4+1}$ is $\dfrac{1}{2}\ln{\left(\dfrac{k^4+1}{k^4}\right)}$.
Is there a closed form solution for the sum of the series $\dfrac{4k}{4k^4+1}$?
Yes, the sum of the series $\dfrac{4k}{4k^4+1}$ can be expressed in a closed form using the natural logarithm function.
How do you prove the formula for the sum of the series $\dfrac{4k}{4k^4+1}$?
The formula for the sum of the series $\dfrac{4k}{4k^4+1}$ can be proved using the technique of partial fractions and telescoping series.
Can the formula for the sum of the series $\dfrac{4k}{4k^4+1}$ be extended to other similar series?
Yes, the formula for the sum of the series $\dfrac{4k}{4k^4+1}$ can be extended to other series with a similar form, such as $\dfrac{ak}{bk^4+1}$ where a and b are constants.
How can the formula for the sum of the series $\dfrac{4k}{4k^4+1}$ be applied in real-world situations?
The formula for the sum of the series $\dfrac{4k}{4k^4+1}$ can be used in various fields of science and mathematics, such as in the study of infinite series, calculus, and engineering. It can also be applied in problem-solving and optimization scenarios.
