Find Tangent Lines Through Origin to a Circle
In summary, to find the equations of tangents to a circle, we can use the family of lines through the origin and set the discriminant to zero. The two tangent lines to x^2+y^2-6x-2y+9=0 through the origin are y=0 and y=\frac{3}{4}x. The respective points of contact are (3,0) and \left(\frac{12}{5},\frac{9}{5} \right).
MarkFL
MHB
13,288
Here is the question:
How to find equations of tangent to a circle?
Find the equations of tangents to
x^2+y^2-6x-2y+9=0
through the origin. Also find their respective points of contact.
thanks
I have posted a link there to this thread so the OP can see my work.
Mathematics news on Phys.org
Hello Princess,
We are given the equation of the circle:
\(\displaystyle x^2+y^2-6x-2y+9=0\)
The family of lines through the origin is given by:
\(\displaystyle y=mx\) where \(\displaystyle m\in\mathbb{R}\)
Substituting for $y$, we obtain the following quadratic in $x$:
\(\displaystyle x^2+(mx)^2-6x-2(mx)+9=0\)
Arranging in standard form, we have:
\(\displaystyle \left(m^2+1 \right)x^2-2(3+m)x+9=0\)
Since the line $y=mx$ is tangent to the circle, the discriminant must be zero:
\(\displaystyle \left(-2(3+m) \right)^2-4\left(m^2+1 \right)(9)=0\)
\(\displaystyle 9+6m+m^2-9m^2-9=0\)
\(\displaystyle 8m^2-6m=0\)
\(\displaystyle m(4m-3)=0\)
\(\displaystyle m=0,\,\frac{3}{4}\)
Thus, the tangent lines are:
\(\displaystyle y=0\)
\(\displaystyle y=\frac{3}{4}x\)
Here is a plot of the circle and the two tangent lines:
To find the contact points, we will substitute for $y$ into the circle:
i) \(\displaystyle y=0\)
\(\displaystyle x^2+0^2-6x-2(0)+9=0\)
\(\displaystyle (x-3)^2=0\)
\(\displaystyle x=3\)
This contact point is \(\displaystyle (3,0)\).
ii) \(\displaystyle y=\frac{3}{4}x\)
\(\displaystyle x^2+\left(\frac{3}{4}x \right)^2-6x-2\left(\frac{3}{4}x \right)+9=0\)
\(\displaystyle \frac{25}{16}x^2-\frac{15}{2}x+9=0\)
\(\displaystyle 25x^2-120x+144=0\)
\(\displaystyle (5x-12)^2=0\)
\(\displaystyle x=\frac{12}{5}\implies y=\frac{9}{5}\)
This contact point is \(\displaystyle \left(\frac{12}{5},\frac{9}{5} \right)\).
FAQ: Find Tangent Lines Through Origin to a Circle
1. What is the equation for finding the tangent lines through the origin to a circle?
The equation for finding the tangent lines through the origin to a circle is y = mx ± √[r²(1 + m²)], where m is the slope of the line and r is the radius of the circle.
2. How do you determine the slope of the tangent lines through the origin to a circle?
The slope of the tangent lines through the origin to a circle can be found by taking the negative reciprocal of the slope of the radius that connects the origin and the point of tangency on the circle.
3. Can there be more than two tangent lines through the origin to a circle?
No, there can only be two tangent lines through the origin to a circle. These lines are always perpendicular to each other and intersect at the origin.
4. How does the radius of the circle affect the tangent lines through the origin?
The radius of the circle directly affects the length of the tangent lines through the origin. The larger the radius, the longer the tangent lines will be.
5. Is there a special case for finding tangent lines through the origin to a circle with a radius of 0?
Yes, when the radius of the circle is 0, the tangent lines through the origin will be the x and y axes. This is because the origin is the only point that satisfies both the equation of the circle and the equation of the tangent lines.
