MHB Find the 18th term in the sequence:
  • Thread starter Thread starter karush
    Sequence Term
The discussion focuses on finding the 18th term in a geometric sequence starting with 1/2, 1, and 2. The formula used is a_n = a_1 * r^(n-1), where a_1 is 1/2 and the common ratio r is 2. The calculations show that a_18 equals 2^(16), which simplifies to 65536. The participants confirm that the formula and ratio used are correct. The final conclusion is that the 18th term in the sequence is 65536.
karush
MHB
Find the $18th$ term in the sequence:
$$\frac{1}{2},1,2 $$
$$a_1= \frac{1}{2}\ \ \ \ n=18\ \ \ \ r=2 $$
$$a_n=a_1\cdot r^{n-1}=131072$$
Mathematics news on Phys.org
I'm thinking:
$$a_n=2^{n-2}$$
And so:
$$a_{18}=2^{16}=65536$$
$$a_n=a_1 \cdot r^{n-1}$$
was the eq in the book unless the ratio is wrong
$$a_n=\frac{1}{2}\cdot 2^{n-1}=\frac{2^{n-1}}{2}=2^{(n-1)-1}=2^{n-2}$$
No, that is correct...I just simplified:
$$a_n=a_1r^{n-1}=2^{-1}\cdot2^{n-1}=2^{n-2}$$
ok got it..
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
