Find the 79th term in the sequence
In summary, the formula for finding the 79th term in a sequence is a(n) = a(1) + (n-1)d, where a(1) is the first term in the sequence and d is the common difference between each term. An example is provided to clarify the process, where the 79th term is found to be 237. If the sequence follows a specific pattern, it may be easier to directly plug in 79 for n in the formula. However, this may not work for all sequences. The first term in the sequence is necessary to accurately find the 79th term using the formula. There is no limit to the length of a sequence that can be used with this formula, as long
karush
MHB
3,269
Find the 79th term in the sequence - 7, - 4, - 1
$$a_n=a_1+\left(a_n-1 \right)d$$
$$n=79,\ \ a_1=-7, \ \ d=-3$$
$$a_{79}=-7+\left(79-1\right)\left(3\right)=227$$
I just followed an example?
Mathematics news on Phys.org
There is a typo
$a_n=a_1+\left(n-1 \right)d$
rest is OK
Gotcha
FAQ: Find the 79th term in the sequence
What is the formula for finding the 79th term in a sequence?
The formula for finding the nth term in a sequence is a(n) = a(1) + (n-1)d, where a(1) is the first term in the sequence and d is the common difference between each term.
Can you provide an example to clarify how to find the 79th term in a sequence?
For example, if the first term in a sequence is 5 and the common difference is 3, the 79th term would be a(79) = 5 + (79-1)*3 = 237.
Is there an easier way to find the 79th term in a sequence?
If the sequence follows a specific pattern or rule, it may be easier to directly plug in 79 for n in the formula. However, this method may not work for all types of sequences.
Can the 79th term be found if the first few terms in the sequence are not given?
No, the first term in the sequence is necessary to find the 79th term using the formula. Without knowing the first term, the 79th term cannot be accurately determined.
Is there a limit to how long a sequence can be to find the 79th term?
No, the formula for finding the nth term in a sequence can be applied to any length of sequence, as long as the first term and common difference are known.
10K
