Find the acceleration vector in terms of u subscript r and u subscript
In summary, to find the acceleration vector in terms of u subscript r and u subscript theta, you first need to find the derivative of r with respect to theta, which is a times sin(theta). Then, using the chain rule, you can find the acceleration vector by taking the second derivative of r with respect to time and plugging in the values for dx/dt and dy/dt. Make sure to use the correct values for r and theta in the equations.
physics_88
Find the acceleration vector in terms of u subscript r and u subscript [tex]\theta[/tex]
r = a(4-cos[tex]\theta[/tex]) and d[tex]\theta[/tex]/dt = 6
Im pretty sure to take the derivative:
r' = a(4+sin[tex]\theta[/tex])
r" = a(4+cos[tex]\theta[/tex])
what should i do next?
Your derivative is not quite right- [itex]dr/d\theta= asin(\theta)[/itex]- the derivative of "4" is 0 since it is a constant. Then, by the chain rule, [itex]dr/dt= asin(\theta) d\theta/dt= 6a sin(\theta)[/itex].
The acceleration vector is [itex]\left<d^2x/dt^2, d^2y/dt^2\right>[/itex]
Of course, [itex]x= r cos(\theta)[/itex] and [itex]y= r sin(\theta)[/itex] so that [itex]dx/dt= (dr/dt)cos(\theta)- rsin(\theta)[/itex],
[itex]dy/dt= (dr/dt)sin(\theta)+ rcos(\theta)[/itex],
[itex]d^2x/dt^2= (d^2r/dt^2)cos(\theta)- 2(dr/dt)sin(\theta)- rcos(\theta)[/itex],
and
[itex]d^2y/dt^2= (d^2r/dt^2)sin(\theta)+ 2(dr/dt)cos(\theta)- rsin(\theta)[/itex]
You were given [itex]d\theta/dt[/itex] before and I gave you [itex]dr/dt[/itex] above.
I appreciate that, but is there more to it.
I don't perfer the answer, but can you guide me through it.
What does it mean u subscript r and u sunbscript theta?
FAQ: Find the acceleration vector in terms of u subscript r and u subscript
What is the definition of acceleration vector?
The acceleration vector is a mathematical quantity that represents the rate of change of an object's velocity over time. It is a vector because it has both magnitude and direction.
How is acceleration vector different from velocity vector?
Velocity vector represents the speed and direction of an object's motion, while acceleration vector represents the rate of change of the velocity vector. In simple terms, velocity is how fast an object is moving, while acceleration is how quickly its velocity is changing.
Can you explain the concept of "u subscript r" and "u subscript" in terms of acceleration vector?
The "u subscript r" represents the unit vector in the radial direction, while "u subscript" represents the unit vector in the tangential direction. These unit vectors are used to decompose the acceleration vector into its radial and tangential components.
How do you find the acceleration vector in terms of "u subscript r" and "u subscript"?
To find the acceleration vector in terms of "u subscript r" and "u subscript", you can use the formula a = (a dot ur)ur + (a dot ut)ut, where a is the acceleration vector, ur is the unit vector in the radial direction, ut is the unit vector in the tangential direction, and a dot represents the dot product of two vectors.
Can you provide an example of finding acceleration vector in terms of "u subscript r" and "u subscript"?
For example, if an object is moving in a circular path with a constant speed of 5 m/s and its radial and tangential accelerations are 2 m/s2 and 3 m/s2 respectively, the acceleration vector can be calculated as a = (2 m/s2 * ur) + (3 m/s2 * ut) = 2ur + 3ut m/s2.
