Find the altitude of the triangle with minimum area
In summary, by stretching the vertical axis of the isosceles triangle circumscribed about the ellipse by a factor of $a/b$ and then shrinking it back to its original position by a factor of $b/a$, the altitude of the triangle can be minimized. This is achieved when the triangle becomes equilateral with a height of $3a$ or $3b$ depending on the direction of the stretch. This solution was deemed extremely clever by Sun.
MarkFL
MHB
13,288
Consider the isosceles triangle circumscribed about the ellipse:
Find the altitude of the triangle when its area is minimized.
Mathematics news on Phys.org
[sp]Stretch the vertical axis by a factor $a/b$. Then the ellipse becomes a circle of radius $a$, and the area of the triangle is minimised when the triangle is equilateral with height $3a$. Now shrink the vertical axis back to where it started (by a factor $b/a$), and the minimising triangle then has height $3b.$[/sp]
Extremely clever, Chris, but then I would expect no less from you! (Sun)
Here is my solution:
I began by orienting the $xy$ axes at the center of the ellipse, and considered the right half of the triangle only. I then labeled the altitude of the resulting right triangle as $h$ and the length of its base as $B$.
The equation of the ellipse is then:
(1) \(\displaystyle \frac{x^2}{a^2}+\frac{y^2}{b^2}=1\)
and the hypotenuse of the right triangle lies along the line:
(2) \(\displaystyle y=-\frac{h}{B}x+(h-b)\)
Substituting for $y$ from (2) into (1), we obtain the quadratic in $x$:
\(\displaystyle \left(\frac{a^2h^2}{B^2}+b^2 \right)x^2+\left(\frac{2a^2h(b-h)}{B} \right)x+a^2h(h-2b)=0\)
Since the ellipse is tangent to the hypotenuse, we require the discriminant to be zero, which implies:
\(\displaystyle h=\frac{2bB^2}{B^2-a^2}\)
And so the area $A$ of the right triangle may be written as as function of $B$ as follows:
\(\displaystyle A(B)=\frac{bB^3}{B^2-a^2}\)
Now, differentiating with respect to $B$ and equating the result to zero, we obtain:
\(\displaystyle A'(B)=\frac{bB^2\left(B^2-3a^2 \right)}{\left(B^2-a^2 \right)^2}=0\)
Since we must have \(\displaystyle a<B\) we find:
\(\displaystyle B^2=3a^2\)
and hence:
\(\displaystyle h=\frac{2b\left(3a^2 \right)}{3a^2-a^2}=3b\)
It is easy to see this minimizes the area of the triangle by the first derivative test.
FAQ: Find the altitude of the triangle with minimum area
What does "finding the altitude of a triangle with minimum area" mean?
Finding the altitude of a triangle with minimum area refers to determining the height of a triangle that has the smallest possible area compared to all other triangles with the same base length.
Why is finding the altitude of a triangle with minimum area important?
Knowing the altitude of a triangle with minimum area can be useful in optimizing space and resources. For example, in architecture, it can help determine the most efficient use of materials for a triangular structure.
How do you find the altitude of a triangle with minimum area?
To find the altitude of a triangle with minimum area, you can use the formula A = 1/2 * b * h, where A is the area, b is the base length, and h is the height. By differentiating the formula with respect to h and setting it equal to 0, you can solve for h and find the minimum area.
Can the altitude of a triangle with minimum area be negative?
No, the altitude of a triangle with minimum area cannot be negative. It is always a positive value, as it represents the distance from the base to the highest point of the triangle.
Are there any real-life applications of finding the altitude of a triangle with minimum area?
Yes, there are many real-life applications of finding the altitude of a triangle with minimum area. It is commonly used in engineering, architecture, and design to optimize space and resources. It can also be used in fields such as transportation and logistics to determine the most efficient route or packaging for triangular objects.
