JustinLiang
- 81
A 1.50-kg ball and a 2.00-kg ball are glued together with the lighter below the heavier one. The upper ball is attached to a vertical ideal spring of force constant 165 N/m, and the system is vibrating vertically with an amplitude of 15.0 cm. the glue connecting them breaks at the lowest point. Find the amplitude and frequency of the vibrations after the lower ball has come loose.
w=sqr(k/m)
F=-kx
The answer is 23.9cm but I don't see how the amplitude could be larger if mass is removed... Unless of course I misread the question...
I initially tried F=kx --> mg=kx --> x=0.12m
