MHB Find the angle between 2 vectors w=i+3j, vector v=<5, 2>
To find the angle between vectors w = i + 3j and v = <5, 2>, first calculate the cosine of the angle using the dot product formula. The cosine can be derived from the formula cos(θ) = (w · v) / (||w|| ||v||). Once the cosine is determined, the sine can be found using the Pythagorean identity sin(θ) = √(1 - cos²(θ)). This method allows for the complete determination of the angle between the two vectors. Understanding both sine and cosine is essential for solving problems involving vector angles.
Elissa89
I know how to find the cos(theta) between two vectors but I do not know how to find the sin(theta).
vector w=i+3j
vector v=<5, 2>
Mathematics news on Phys.org
vector w=i+3j
vector v=<5, 2>
find the cosine, then use a form of the Pythagorean identity ...
$\sin{t} = \sqrt{1-\cos^2{t}}$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
