Find the angle that the vector R
In summary: The answer was 157.26.In summary, the conversation discusses finding the magnitude and angle of a vector R in the xy plane given two vectors A and B with their corresponding components. The magnitude of R is found using the distance formula, while the angle is found using the arctan function. The conversation also includes a correction for the cosine law formula and a reminder to consider the quadrant when using the arctan function.
NINHARDCOREFAN
118
part 1 of 2
Two vectors A and B, are lying in the xy
plane and given by
A = Axi +Ayj
B = Bxi +Byj
(x y are subscripts)
where A x = 4.4 m, A y = 1.74 m, B x = 7.58 m, B y = -6.76 m. Let R = A+B.
Find the magnitude of R. Answer in units
of m.
So it is
A = 4.4mI + 1.74mJ
B = 7.58mI - 5.02J
I have found out R by using the distance formula
sqrt(11.98^2 + 5.02^2) = 12.9893 m(which is right)
part 2 of 2
Find the angle that the vector R makes from
the positive x axis. Choose your answer to be
between -180 # and +180 # . The positive an_
gular direction is counter clockwise measured
from the x axis. Answer in units of # .
I tried this problem using the cosine law.
-5.02squared-11.98squared-12.99squared
______________________________________(division)
-2*11.98*12.99
I got 22.73 degrees. But when I sumbit this answer, it says I'm wrong. Can you figure out what I'm doing wrong?
The angle you are looking for, the angle the vector R makes with the x-axis is NOT an angle in the triangle formed by the three vectors. Also, you have the cosine law wrong (it may be a typo).
It is a^2= b^2+ c^2- 2bc cos(A) so cos(A)= (a^2- b^2- c^2)/(2bc).
In any case, the simplest way to do this is to look at the vector
R only. You know the components of R. Look at the right triangle formed by the vector and it's components and think "tangent"!
of m.
So it is
A = 4.4mI + 1.74mJ
B = 7.58mI -5.02J
By is incorrect (it's the y-comp of R), but it looks like you caught that in the next part.
part 2 of 2
-2*11.98*12.99
I got 22.73 degrees. But when I sumbit this answer, it says I'm wrong. Can you figure out what I'm doing wrong? [/B]
Just find the arctan. rise/run = tan θ , so atan (rise/run) = θ
Be sure you know what quadrant you're in. atan is only defined for +- 90 degrees, so you will need to add 180 degrees if you're in the second or third quadrants.
After I did that I got 22.74, the same answer as I did before, which is wrong.
The answer was -22.74(QIV), which is same as 22.74(QI)
Why is "-22.74(QIV)" the same as "22.74(QI)"? They look very different to me!
I figured that out last night, I thought the problem said that answer has to be between 0 and 180 but then realized that it was between -180 and 180.
FAQ: Find the angle that the vector R
What does "Find the angle that the vector R" mean?
"Find the angle that the vector R" refers to finding the angle made by a vector R with the x-axis on a coordinate plane. This angle is measured counterclockwise from the positive x-axis.
What is a vector?
A vector is a mathematical object that has both magnitude and direction. It is represented by an arrow pointing in a specific direction, and the length of the arrow represents the magnitude of the vector.
How do you find the angle of a vector?
To find the angle of a vector, you can use trigonometric functions. The angle can be calculated by taking the inverse tangent of the y-coordinate of the vector divided by the x-coordinate of the vector. Alternatively, you can use the dot product or cross product of two vectors to find the angle between them.
Why is finding the angle of a vector important?
Finding the angle of a vector is important in many mathematical and scientific applications. It can help determine the direction of a force or velocity, and it is a crucial component in solving problems related to vectors and coordinate systems.
Can the angle of a vector be negative?
Yes, the angle of a vector can be negative. This occurs when the vector is pointing in the clockwise direction instead of the counterclockwise direction. In this case, the angle is measured in the clockwise direction from the positive x-axis, and it has a negative value.
