Find the antiderivative of V(2−x−x^2)/x^2
In summary, an antiderivative is a function that is the inverse operation of differentiation and can be found for any continuous function using techniques such as integration by parts, substitution, and partial fraction decomposition. To find the antiderivative of a rational function, one must first simplify the function and then use partial fraction decomposition to break it down into simpler fractions. The antiderivative of each fraction can then be found and combined to get the final answer.
lfdahl
MHB
749
Find the antiderivative, $F$, of the function $$f(x) = \frac{\sqrt{2-x-x^2}}{x^2}.$$
Mathematics news on Phys.org
The answer to this challenge is neither short nor elegant. In addition the solution path is quite winded.
I´m sorry for having posted the challenge, which seemingly doesn´t contain the mathematical beauty, that
can be found in many other challenges (Sadface)Suggested solution:
From $2-x-x^{2} = (2+x)(1-x)$, it seems a good idea to use the substitution $2+x=y^{2}(1-x).$
Hence, we get:
\[ x=\frac{y^{2}-2}{y^{2}+1}\] and \[dx=\frac{6y}{(y^{2}+1)^{2}}\ dy.\]
and \[\sqrt{2-x-x^{2}}= (1-x)y= \frac{3y}{y^{2}+1}.\]
Thus, our integral/antiderivative can be rewritten in terms of $y$ as:
\[F=\int \frac{3y}{y^{2}+1} \cdot \left (\frac{y^{2}+1}{y^{2}-2} \right )^{2} \cdot \frac{6y}{(y^{2}+1)^{2}}\ dy\]
\[F=\int \frac{18y^{2}}{(y^{2}+1)(y^{2}-2)^{2}}\ dy\]
\[F=\int \left[\frac{2y^{2}+8}{(y^{2}-2)^{2}}-\frac{2}{y^{2}+1}\right]\ dy\]
\[F=\int \frac{2y^{2}+8}{(y^{2}-2)^{2}}\ dy-2\arctan y\]
Using the identity: \[\left(\frac{y}{y^{2}-2}\right)'=-\frac{y^{2}+2}{(y^{2}-2)^{2}}.\]
yields
\[F=\int \frac{3y^{2}+6-(y^{2}-2)}{(y^{2}-2)^{2}}\ dy-2\arctan y\]
\[F=3\int \frac{y^{2}+2}{(y^{2}-2)^{2}}\ dy-\int \frac{1}{y^{2}-2}\ dy-2\arctan y\]
\[F=-\frac{3y}{y^{2}-2}-\int \frac{1}{(y+\sqrt{2})(y-\sqrt{2})}\ dy-2\arctan y\]
\[F=-\frac{3y}{y^{2}-2}-2^{-\frac{3}{2}}\int \left (\frac{1}{y-\sqrt{2}}-\frac{1}{y+\sqrt{2}}\right)\ dy-2\arctan y\]
\[F=-\frac{3y}{y^{2}-2}-2^{-\frac{3}{2}}\ln \left ( \frac{y-\sqrt{2}}{y+\sqrt{2}} \right )-2\arctan y + C\]
Backsubstitution with $y=\sqrt{\frac{2+x}{1-x}}$, yields:
\[F = 2^{-\frac{3}{2}}\ln \left ( \left | \frac{4}{x} - \frac{2^{\frac{3}{2}}\sqrt{-x^2-x+2}}{x} - 1\right | \right )-\frac{\sqrt{-x^2-x+2}}{x}+\arctan\left (\sqrt{ \frac{2+x}{1-x} }\right )+C’\]
I had this problem on a list of things to think about when I have some spare time. Having seen the solution, I'm glad I never got round to it. (Shake)
FAQ: Find the antiderivative of V(2−x−x^2)/x^2
What is an antiderivative?
An antiderivative is a function that, when differentiated, gives the original function. It is the inverse operation of differentiation.
Can the antiderivative of any function be found?
Yes, the antiderivative of any continuous function can be found using various techniques such as integration by parts, substitution, and partial fraction decomposition.
What is the process for finding the antiderivative of a rational function?
The process for finding the antiderivative of a rational function involves first simplifying the function and then using the technique of partial fraction decomposition to break it down into simpler fractions. The antiderivative of each individual fraction can then be found using the power rule or other integration techniques.
How do you find the antiderivative of V(2−x−x^2)/x^2?
To find the antiderivative of this specific function, first rewrite the function as (2-x-x^2)/x^2 and then use the technique of partial fraction decomposition to break it down into simpler fractions. The antiderivative of each fraction can then be found using the power rule or other integration techniques.
What are the steps for finding the antiderivative of a rational function using partial fraction decomposition?
The steps for finding the antiderivative of a rational function using partial fraction decomposition are as follows:1. Simplify the rational function if necessary.2. Factor the denominator to determine the form of the partial fractions.3. Set up a system of equations and solve for the unknown coefficients.4. Rewrite the original function using the partial fractions.5. Find the antiderivative of each individual fraction.6. Combine the antiderivatives to get the final answer.
