Find the apogee from v at perigee, perigee, g, and the radius of Earth
  • Thread starter Thread starter Natchanon
    Earth Radius
To find the apogee and orbital period of a satellite given its perigee and tangential speed at perigee, one can utilize the gravitational constant g and the Earth's radius without needing the Earth's mass. The relationship between gravitational acceleration and the gravitational parameter allows for the calculation of the necessary parameters. By applying conservation of angular momentum, the maximum radius can be derived from the perigee and the velocities involved. The discussion clarifies that the gravitational parameter can be inferred from g and the Earth's radius, facilitating further calculations. This approach enables the completion of the problem without directly using the Earth's mass.
Natchanon
Satellite orbits the Earth and its perigee r_min and tangential speed at perigee v_pe are given. The problem says do not use mass of Earth in the calculation, and use the only the constants g = 9.8 and radius of Earth 6380 km. I'm supposed to find the apogee and orbital period, but not using mass of Earth makes things seem so complicated. And the formula for period itself has mass of Earth in it.
where ecc is eccentricity
perigee = r_min + radius of Earth
r_max = (1+ecc)*r_min/(1-ecc)
Since argular momentum is conserved,
m v_pe r_min = m v_ap r_max
=> r_max = v_pe r_min / v_ap
I tried to find v_ap, but that the formula has mass of Earth in it, so I can't use that.
Thank you
But given g and the radius of the Earth you can infer the gravitational parameter ##\mu = GM_e##, right?
So what you meant is
g = GM/r_earth^2 = μ/r_earth^2
=> g*r_earth^2 = μ ? That makes sense. Thank you.
Likes gneill
Yup. And so you can proceed with the rest of the usual basic orbital motion equation lexicon.
Likes Natchanon
  • · Replies 18 ·
11K
21K
