Find the area and length of a gold leaf
Yes3) 0.2 cm^3 / 0.0005372 cm= 372.3927 cm^24) 372.3927 cm^2 * 1 m^2 / 10,000 cm^2= 0.0372 m^2[part B]1) 2.300 μm * 1 cm / 10,000 μm= 0.00023 cmYes, but it should be 0.023 cm2
MachineInTheStone
Gold, which has a density of 19.32 g/cm3, is the most ductile metal and can be pressed into a thin leaf or drawn out into a long fiber. (a) If a sample of gold with a mass of 3.872 g, is pressed into a leaf of 5.372 μm thickness, what is the area of the leaf? (b) If, instead, the gold is drawn out into a cylindrical fiber of radius 2.300 μm, what is the length of the fiber?
d = m/v
v = pi * r^2 * L
v = l*w*h
d = m/v[/B]
[Part A]
1) 19.32 g / 1 cm^3 = 3.872g / v
v = 4.98967 cm^3
2) 5.372 micrometer * 1 cm / 10,000 micrometer
= 0.0005372 cm
3) 4.98967 cm^3 / 0.0005372 cm
= 9288 cm^2
4) 9288 cm^2 * 1 m^2 / 10,000 cm^2
= 0.9288 m^2
[part B]
= 0.00023 cm
2) v = pi * r^2 * L
Since v = 4.98967 cm^3 ...
4.98967 cm^3 = pi * (0.00023 cm)^2 * L
4.98967 cm^3 = 0.0000001662 cm^2 * L
L = 30022100 cm
3) 30022100 cm * 1 m / 0.01 cm
= 3,002,210,000 m
Are part A and B correct?
B seems totally wrong!
MachineInTheStone said:
L = 30022100 cm
= 3,002,210,000 m
How come the number is bigger in m than in cm!?
Likes BvU
ah.
L = 30022100 cm
3) 30,022,100 cm * 1 m / 100 cm
= 300,221 m
Is part A and B correct now?
v = 4.98967 cm^3
No. 1/v = 4.98967 cm-3
Likes MachineInTheStone
Related to Find the area and length of a gold leaf
1. What is the formula for finding the area of a gold leaf?
The formula for finding the area of a gold leaf is length x width.
2. How do I measure the length and width of a gold leaf?
To measure the length and width of a gold leaf, use a ruler or measuring tape. Place the gold leaf on a flat surface and measure the longest and widest points.
3. Can I use any unit of measurement for finding the area and length of a gold leaf?
Yes, you can use any unit of measurement as long as you are consistent with your calculations. Common units for measuring length and area include inches, centimeters, and millimeters.
4. Do I need to account for the thickness of the gold leaf when finding the area and length?
No, the thickness of the gold leaf does not need to be accounted for when finding the area and length. The focus is on the flat surface of the gold leaf, so only the length and width should be measured.
5. What is the purpose of finding the area and length of a gold leaf?
Finding the area and length of a gold leaf is important for various purposes, such as determining its value, calculating the amount needed for a project, or ensuring proper coverage when using the gold leaf for decoration or gilding.
