MHB Find the area of sector in a circle in terms of pi. (Geometry)
To find the area of a sector in a circle, the formula involves multiplying the fraction of the circle represented by the angle by the area of the entire circle. In this case, the angle of 270 degrees simplifies to 3/4 when divided by 360 degrees. The area \(A\) is calculated as \(A = \frac{3}{4}\pi r^2\). With a radius of 12 meters, substituting into the formula gives an area of 108π. The final answer of 108π is confirmed as correct.
Etrujillo
So far i have 270/360× (pi)r^ i don't know what to do next please help.
Mathematics news on Phys.org
I would first reduce:
$$\frac{270^{\circ}}{360^{\circ}}=\frac{3}{4}$$
And so we now have the area \(A\):
$$A=\frac{3}{4}\pi r^2$$
Can you identify the radius \(r\) of the circle from the diagram?
The radius i believe is 12m so when i plug in your formula i get 108pi as the answer. Am i correct?
Yes, 108\pi is correct.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
