MHB Find the area of the metal plate
  • Thread starter Thread starter Mango12
    Area Metal Plate
To find the area of the metal plates given a capacitance (C) of 3,000, permittivity of free space (Epsilon0) as 8.85 × 10^-12, and a separation distance (delta x) of 0.5 mm, the formula C = Epsilon0(A)/delta x is used. The user is seeking clarification on the problem's requirements and has reiterated the need for all relevant information to be included for accurate assistance. Despite calculating an area that resulted in 1.6 × 10^11 meters, the expected answer should be approximately 40,000 meters. The discussion emphasizes the importance of providing complete context when seeking help with physics problems. Accurate calculations and understanding of the relationships between capacitance, area, and distance are crucial for solving this problem.
Mango12
I know C=Epsilon0(A)/delta x
From the problem, C=3,000
Epsilon0 = 8.85 × 10^-12
and delta x is .5mm
The answer is supposed to be given in meters and should be close to 40,000 but I got 1.6*10^11m...help please!
Mathematics news on Phys.org
Can you state the entire problem as given?
Now let's find the area of the metal plates. We already know from a previous problem that there is a 3,000 coulomb charge on the plates. The plates are placed .5mm apart. (approximate answer is 250 miles, but give your answer in meters)
If a problem depends on a previous problem, then you need to give all relevant information, all in one place, so people don't have to guess at what's going on or chase the information down in other threads. (Whew)
Yes..I have given all relevant information that I know. I know the charge in coulombs and the distance between the plates. Epsilon nought is a given number. And I need to solve for area.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
