MHB Find the area of the red region
  • Thread starter Thread starter anemone
    Area
The discussion focuses on calculating the area of a red region within a parallelogram, where the areas of adjacent green regions are provided as 8 unit², 10 unit², 72 unit², and 79 unit². Participants analyze the relationships between these areas to derive the area of the red region. The total area of the parallelogram is implied to be the sum of the green regions plus the red region. By applying geometric principles and area calculations, the participants aim to find the value of the red region. The conclusion emphasizes the importance of understanding area relationships in geometric figures.
anemone
MHB
POTW Director
The diagram below (which is not drawn to scale) shows a parallelogram. The area of the green regions are 8 unit² , 10 unit² , 72 unit² and 79 unit² respectively. Find the area of the red region.
[TIKZ]
\coordinate (A) at (0,0);
\coordinate (B) at (8,0);
\coordinate (C) at (12,0);
\coordinate (D) at (12.75,3);
\coordinate (E) at (14,8);
\coordinate (F) at (6,8);
\coordinate (G) at (2,8);
\coordinate[label=above: \huge 79] (P) at (4.5,3);
\coordinate[label=above: \huge 72] (Q) at (9.5,6);
\coordinate[label=above: \large 8] (R) at (8.5,1.2);
\coordinate[label=above: \large 10] (S) at (11,2.9);
\draw (A) -- (C)-- (E) -- (G) -- (A);
\draw (A) -- (F);
\draw (A) -- (D);
\draw (B) -- (F);
\draw (B) -- (E);
\draw (D) -- (G);
\draw[fill=teal] (0,0) -- (7.564,1.745) -- (6.513,5.949) -- (4.983,6.644);
\draw[fill=teal] (6,8) -- (6.508,5.931) -- (10.93,3.85) -- (14,8);
\draw[fill=teal] (8,0) -- (7.564,1.76) -- (9.674,2.25);
\draw[fill=teal] (10.92,3.89) -- (12.75,3) -- (9.674,2.25);
\draw[fill=teal] (4.5,3) node[text=pink] {\huge 79};
\draw[fill=teal] (9.5,6) node[text=pink] {\huge 72};
\draw[fill=teal] (8.5,1.2) node[text=pink] {\large 8};
\draw[fill=teal] (11,2.9) node[text=pink] {\large 10};
\draw[fill=magenta] (2,8) -- (4.983,6.644) -- (6,8);
[/TIKZ]
Mathematics news on Phys.org
Area of triangle
[TIKZ]
\coordinate[label=above: \huge A] (M) at (2.5,5);
\coordinate[label=above: \huge B] (N) at (6,0.48);
\coordinate[label=above: \huge C] (Z) at (5.8,6.8);
\coordinate[label=above: \huge D] (J) at (8.5,3.2);
\coordinate[label=above: \huge E] (K) at (10.5,0.9);
\coordinate[label=above: \huge F] (I) at (12.2,4.2);
\draw (A) -- (F);
\draw (A) -- (D);
\draw (B) -- (F);
\draw (B) -- (E);
\draw (D) -- (G);
[/TIKZ]
If we look at the parallelogram in such a way that the horizontal sides are the base, then we have
$\normalsize \text{Area of B}+\text{Area of C}+79+\text{Area of E}+\text{Area of F}+10=\text{Area of A}+\text{Area of red region}+72+8+\text{Area of D}$
If we look at the parallelogram in such a way that the slanted sides are the base, then we have
$\normalsize \text{Area of B}+\text{Area of E}+8+\text{Area of F}+\text{Area of C}+72+\text{Area of red region}=\text{Area of A}+79+10+\text{Area of D}$
Subtracting the below from the above we get
$ 9-\text{Area of red region}=-9+\text{Area of red region}\\ \\ \therefore \text{Area of red region}=9$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
